#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Think you're barking up the wrong tree with that thought. 6th gear is the top speed gear for a stock A8 Camaro SS. The Corvette is lighter and sleeker so it will accelerate quicker and run a higher top speed if the computer allows it. Meaning there is no reason for them to fear the Camaro keeping up if both were completely unrestricted. The Camaro SS Coupe does have a governor set at 180 in the ECM, don't know if the Corvette has such a setting in it.
#16 | |
It's at the dealer again now. I told them to keep it as long as they need to figure this out. I have a full kooks exhaust sitting in my garage waiting to be installed and then it's going to get tuned. Before I trash my warranty this needs to be taken care of. |
#17 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
I really think its happening due to the converter failing to lockup quickly enough after the shift. It's so weird though that it doesn't affect any other gear. I mean I assume its not happening on the 5-6 shift but how often can you do 140mph+ on the street to test that?
#18 |
![]() Drives: 2017 Camaro 1SS A8 Join Date: Jan 2017
Ok maybe a bit farfetched but regardless there is something funky going on. Someone was telling me that the gear ratios change drastically from 4th to 5th but not something that would make it appear as if the TC is slipping...
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Join Date: Jul 2016
Is the TB blade staying open? Or I should say re-opening after the shift at the proper point. I put one of my ported IM/TB combo's on a 17' C7 GS the other day and we were exceeding the TQ tables in either the Driver Demand, ECM, TCM. It was closing the blade. It took a bit of tuning to get it out. With just the IM/TB and a tune we dropped .4 in the 1/8 and .5 in the 1/4. We gained 4+mph. But on the stock tune it would close the blade bad with TM and went slower than stock. That car is sensitive. Check your logs for blade closure.
#20 |
Shift recovery from 1/2, 2/3, and 4/5 are the same 1,500 rpm drop. The 3/4 only drops about 1K rpm. So the 3/4 feels much harder than the 4/5. The trans pressures seem to be set up to compensate for this though. Most people say the 4/5 feels like the hardest shift. It could be possible also that if the trans is slipping or the converter isn't locking that you are hitting the limiter during the shift and that is shutting you down for a sec also.
#21 | |
Snackbar Tuning
![]() I had to email it to you separately as I could not attach on here. |
#22 | |
#23 |
Snackbar Tuning
Thanks Bret, I'm actually going to try to turn traction control off and datalog/test again. I spoke to my service adviser and tech today at the dealer and the tech asked if I could test that for him. He thinks the ECU is seeing something to keep TMA active rather than the torque converter having an issue.
#24 | |
#25 | |
#26 | |
I took it WOT (in mexico of course) all the way to 5th gear and the car shifted perfectly. No more lag or abrupt hard shifts at all. I spoke to the tech that worked on the car and he said he data logged the car while driving it around for a few days ( I gave them permission) and he found some issues with the shift points in the ECU. He didn't go into specifics with me but said it was all fixed by making some adjustments to the way the transmission shifted in the ECU. So far it seems like my nightmare has ended and the mods can finally begin. I'm going to hold off for another few weeks just to make sure it's solid. If all goes well headers and a fulll kooks exhaust with the dyno tune after. |
#27 |
Thanks for you all's input regarding this. Is there some type of direct troubleshooting I can do to figure out which is which? My car barks 1/2, 2/3,3/4, and slurs like Jack sparrow 4/5. I do have your Ported tb/im as well as a dry rotofab running on the stock tune.
#28 | |
