Old 10-01-2017, 08:28 PM   #15
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
Originally Posted by JFM-jr View Post
I have stations here on Long Island that test at E90
Out of curiousity, what is the testing method?
RCF is offline   Reply With Quote
Old 10-01-2017, 08:43 PM   #16
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
as far as my tuner testing it i have no idea how he tested it but its at Noco stations.
Old 10-01-2017, 09:35 PM   #17
KonigWolf
Drives: 2016 2SS A8
Is there anyone E85 kit better than the others? Or are they all fundamentally the same?
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 10-01-2017, 10:16 PM   #18
JCunningham
Drives: 2017 2SS M6
some come with a fuel line that fits better than the oem no E85 one. other then that there the same.
Old 10-02-2017, 02:26 AM   #19
JohnE
Drives: 2016 Camaro SS / 1SS
As others have pointed out on another thread, the sensor kits vary. I would say that $200 should be the maximum price for the hardware. The flexfuel sensor is a standard GM part. All of the kits will ultimately have to tie into pin #38 of the ECU for it to work. The rest of it is getting 12V and ground.
The expensive part will be the tuning device. I bought the HP Tuners suite for $499.00.
As far as the MPG goes. My first tank of E85 showed up as 66% ethanol due to the fact that I still had a few gallons of regular gas in the tank.
My average of 20.5 MPG was probably based on 5-10% ethanol. The pumps by me say that E85 is a minimum of 51% ethanol. Ethanol is a boondoggle in that it is "green". You would think that it would cost more to brew up a gallons of ethanol than to pump a gallon of oil out of the ground. I bet that it is not too profitable to brew it up at the full 85% ethanol, but who knows.
I'm gonna redo my math on my efficiency factor considering these things. But my gut feel is that the efficiency ratio is closer to 80%.
JohnE is offline   Reply With Quote
Old 10-02-2017, 03:50 PM   #20
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
I have 2 e85 stations in either direction less than 1/2 mile from my house. I was able to squeak out 19 but there were some highway miles along with street lights and traffic jams on the highway. Not bad at all. My last dyno was 453hp and 456tq. Best I got on 91 was 21mpg
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 10-02-2017, 03:53 PM   #21
BowtieRocket
Originally Posted by RCF View Post
If I'm not mistaken, official E85 spec is like 51-85% ethanol. Not saying it couldn't be different as stations can blend their own.
Local pumps are consistent 64%. The one by the drag strip is in the 70s
Old 10-02-2017, 10:19 PM   #22
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
On your OP you mention that you’re new to tuning... how didnyou go about didyou download a tune from somewhere o to played with the tuner and did a custom tune yourself... i actually purchased a hp tuner pro (it came in a bundle) and now i dont know if i should get rid of it and pay for a tune or how to proceed.
Florida High Performance: H/C Whipple LME 377 900WHP
G2K is offline   Reply With Quote
Old 10-02-2017, 11:34 PM   #23
JohnE
Others have posted a reference tune on this site. But, if you look on the forums at HP Tuners, there are a lot of sample "tunes" there.
I can do a quick write-up if you need additional info or if you want the tune I used. Feel free to reply or PM me.
-John
Old 10-02-2017, 11:40 PM   #24
JohnE
Good numbers. For my numbers, I've tried to drive it the same way I did on normal gas.
What do you pay for E85 in NM? Today, right by O'hare airport in Illinois, I saw E85 for $1.75 per gallon. Can't beat it. :-)
Old 10-07-2017, 09:33 PM   #25
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
-John
I sent you a PM! thanks!
Old 10-08-2017, 01:02 PM   #26
BowtieRocket
It was about $1.89 but now it's up to $2.09
Old 10-08-2017, 10:37 PM   #27
JohnE
By me, E85 seems to vary a lot in price. I use the gasbuddy app now. My last fill up was at $1.63, but there were stations selling it at $2.09 as well. I would think ethanol would be cheapest near the midwest just based on the fact that its corn based.
I've only recently started to pay attention to the price of E85, but I think there is a seasonal component to the price as well. What I do is the following.... I take the price of E85 and divide it by my efficiency ratio (call it 80% even though my current one is around 84%). If the resulting price is lower than premium unleaded, then fill up with E85, otherwise use premium. I noticed that my exhaust tips are looking cleaner now too.
Old 10-08-2017, 10:56 PM   #28
Mrpilotman321
Mrpilotman321's Avatar
Drives: 2017 HyperBlue 2SS
I know the car can utilize flex fuel with a tune. Does switching to E85 void warranty? Also, can dealer perform the switch on the vehicle?
Mrpilotman321 is offline   Reply With Quote
