Old 06-14-2018, 12:38 PM   #15
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
I have Zach Bowmans Cam/Head car leaving dropping the clutch on the 2step at 6000 rpm, No throttle, Fuel, or Spark cut. No torque intervention. With using the existing tables available in HPT Beta software. I have data logs and screen shots to back up the claims.....lol
Rhino79 is offline   Reply With Quote
Old 06-14-2018, 12:48 PM   #16
Rhino79
Rhino79's Avatar
Here are screenshots.
Old 06-14-2018, 12:55 PM   #17
DFW1LE
DFW1LE's Avatar
Ryan, Are good launches only possible with the 2 step, at least consistent ones?
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 06-14-2018, 01:19 PM   #18
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
interesting....
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 06-14-2018, 05:45 PM   #19
Rhino79
Rhino79's Avatar
Absolutely. Put a stiff wall slick with tubes like a m6 car should have and it will leave great. Always a balance of finding the right amount of wheelspeed.
Old 06-17-2018, 01:17 PM   #20
Getinthur
Drives: 2017 ZL1
I emailed you about this like 2 weeks ago.
Getinthur is offline   Reply With Quote
Old 06-20-2018, 06:40 PM   #21
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Not to sound pompous but I don't believe a head/cam car makes enough power to produce the bog. I'll let someone with more tuning experience explain what the variables that cause it are.
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol //
(purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills)
// 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap //
exxit is offline   Reply With Quote
Old 06-24-2018, 05:46 AM   #22
Getinthur
Drives: 2017 ZL1
The bog has nothing at all to do with the power being made. The bog is strictly a combination of the throttle being told to close and power being removed from the car by pulling timing.
Old 06-25-2018, 10:54 AM   #23
exxit
I should have been more clear. It is more prominent with power and seemingly non-problematic until 600+whp. I think the reason it is even an issue was stated a few times. HP tuners didn't have the table available or it was/is locked. I believe it is a torque management table. This is completely specific to the M6 though. The auto guys seem to be able to be tuned to leave hard without nannies kicking in.
Old 06-25-2018, 11:24 AM   #24
DFW1LE
DFW1LE's Avatar
Many NA M6 cars are below 600whp, but still have problems launching. Note what Ryan said above about using a 2 step and launching at 6K.
Old 06-25-2018, 01:58 PM   #25
6spdhyperblue
Drives: 2SS 1LE
That’s assuming those are the parameters that can prove the claim.
Is that throttle percent at the pedal or throttle blade? are we sure the throttle is staying open? If you can wire an independent tps to view throttle actual would be helpful.
What’s the car 60?
Old 07-10-2018, 09:55 PM   #26
exxit
Is it possible that the beta included the tables that were previously inaccessible?
