Old 09-19-2017, 12:00 PM   #15
TEEZYSS
Drives: 2016 CAMARO 2SS
I read about the false knock and I commented on it in my previous post. However it seems to be hit or miss. The factory cat pipes are thicker and do not amplify engine noises like headers and cat delete pipes do. That is why I mentioned wrapping them.
Definitely not against you just throwing out what I have seen about them. I have yet to install mine but ill be doing it after I throw on my E85 kit and TUNE.
On a side note, I'm going with Bullets instead of CA. I found the Bullets on Vengeance racing ebay page for a better price. Plus they have the hanger brackets.
http://www.bulletperf.com/chevrolet/...at-delete.html
Is $362 with gaskets?
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248
PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664
GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next...
TEEZYSS is offline   Reply With Quote
Old 09-19-2017, 12:41 PM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No worries...did not think you were knocking me. My apologies if I came off that way.
I dont think so. I paid less for mine from vengeance ebay site.
Old 09-19-2017, 12:45 PM   #17
TEEZYSS
That's not a bad price though... I gave $399 from CA with GM gaskets.
I'm trying to do everything in stages and track it to see the gains for fun.
Old 09-19-2017, 12:46 PM   #18
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
....I decided to buy the Bullet performance bolt-in delete pipes and I will use the rear o2 adapters from Big Daddies garage that pull the rear o2's away from the exhaust stream which keeps the PCM from throwing a cell. So I should not need to hook up my HP tuners and void the warranty by turning the codes off.
I'm assuming that you plan on using the Big Daddies adapters that have the catalytic material in them, correct? If you do this, I'm very interested in how the adaptors work out. Particularly if you can run code free without a tune.
Atomic Ed is offline   Reply With Quote
Old 09-19-2017, 03:39 PM   #19
KingLT1
KingLT1's Avatar
Yes that is correct.
Yea I got them for 275.00 shipped minus the gaskets. I think they were used very shortly on a ZL1 before going long tubes.
Old 09-20-2017, 04:35 PM   #20
Redlinez
Shifts under load
Redlinez's Avatar
Several thousand miles since having my Cat delete, no check engine light, no other obvious issues. I did also have the dealer do my free oil change and I've noticed my MPG's have gone down about .8 mile per gallon. I was running the expensive Valvoline synthetic just before they changed it. Haven't been using the a/c as much either. I used to stay dead on 22mpg, now 21.2
22 Suzuki GSX-S 1000GT blue
Old 09-20-2017, 08:24 PM   #21
Techn9cian805
The BEAST
Techn9cian805's Avatar
Drives: '16 2SS, '89 Wife
First i hear of those big daddies things. I loom forward to seeing if it really works
Scarlet: 3/3/16: 2SS Red Hot, M6,
Instagram: @luis_what_it_is
Techn9cian805 is offline   Reply With Quote
Old 09-23-2017, 12:07 PM   #22
KingLT1
KingLT1's Avatar
Delete pipes are ready to go on.
Old 09-23-2017, 07:30 PM   #23
KingLT1
KingLT1's Avatar
Delete pipes installed.
Hookep up HP tuners and logged some data....Stock Tune.
Old 09-25-2017, 12:04 PM   #24
KingLT1
KingLT1's Avatar
A little update.
150 miles no CEL yet. Also not seeing any KR. Sound in Stealth mode is about like the Stock setup open but a little tinny sounding. Open it gets LOUD! However there is not a hint of drone in either mode. For the price this is not a bad mod. I do think the Stock NPP unmolested sounds more refined per say. Performance wise its hard to tell yet.
Old 09-25-2017, 12:43 PM   #25
Mullet_Machine
Drives: SRT4, 2ss
Nice. Thanks for the update.
Mullet_Machine is offline   Reply With Quote
Old 09-25-2017, 01:36 PM   #26
Techn9cian805
The BEAST
A little update.
So those Big Daddy o2 minicats thingamabobs work? Nice! Definitely keep us updated if the CEL does happen to come on at any point. Thanks for the update!
Questions: KR? Knock readings? And why the header wraps? I'm not experience with them and am curious to know why put them on cat deletes, and what are the pros/cons.
Old 09-25-2017, 02:21 PM   #27
KingLT1
KingLT1's Avatar
I was sent the "Cel Fix" adapters with no catalayst material. So we packed the base with a light amount of steel wool. That is what my brother used on his 2016 Scat Pack Challenger and has had no issues for 2yrs. Camaro may be different we shall see.
Yes KR means Knock retard. If you look at the log I posted, the histogram in the upper right hand corner is for KR. I woynd the engine out to 6400 and nothing. Fuel trims were also in check.
The idea of the header wrap was to "quiet" down the pipes. It was mentioned that the LT1 computer could potentially pick up the increased noise via the knock sensors. Normally aftermarket headers and cat delete pipes are thinner and you can hear ticking in the pipes. So I did the wrap as a preventative measure. Also reduces engine bay temps.
Old 09-25-2017, 02:28 PM   #28
Techn9cian805
The BEAST
Thanks for the reply, bro, i'm new to all this so its cool to learn this.
