Old 09-17-2017, 04:05 PM   #15
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Originally Posted by VAZL1 View Post
661.00 for a CAI, wow!! Don't get me wrong to each his own, looks good on your car but that price is total BS.
The extra is for the real Carbon Fibre.
Sent from my SM-G955U using Tapatalk
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 09-17-2017, 04:27 PM   #16
djfury05
djfury05's Avatar
Drives: 2017 ZL1 A10
I literally had ZERO issues getting the stock fitting out that everyone is complaining about. I didn't even loosen the oetiker clamp. I grabbed it with my pliers and pulled it out with some effort. Not even hard.
After seeing these pics I'm certainly glad I went with the Rotofab setup. Filter is smaller by a good bit. To each their own though.
djfury05 is offline   Reply With Quote
Old 09-17-2017, 05:23 PM   #17
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
If K/N sourced a fitting why can't RotoFab?
Some guys say the OEM fitting came out real easy, some said it was a bitch.
Shouldn't be an issue, just include the fitting, I'm sure it wouldn't cost much.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 09-17-2017, 05:58 PM   #18
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Filter is WAY larger than needed to flow stock power levels. If it was a restriction your point would be valid.
ninetres is offline   Reply With Quote
Old 09-17-2017, 06:12 PM   #19
ninetres
ninetres's Avatar
Originally Posted by bobby35ny View Post
Does the K/N have the 2 plates inside the tube by the MAF sensor?
-Bobby
No. The MAF goes in a separate plastic tube the bolts to the shield.
Old 09-17-2017, 07:24 PM   #20
BlaqWhole
Drives: 2017 Camaro ZL1 A10
This whole clamp nonsense. I broke mine right off without a second thought. I'll get a standard clamp or something if I ever go back to stock. It isn't even worth mentioning.
Old 09-17-2017, 07:28 PM   #21
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Its NOT nonsense when you get a warranty problem...:(
Not all of us have friendly dealers, I have to swap to OEM if the car goes to the dealer. I have 3 dealers within 20 miles, all 3 are dicks..:(
Old 09-17-2017, 07:36 PM   #22
Fast Dalmation
Fast Dalmation's Avatar
Drives: 2018 Summit White ZL1 1LE
What would you do with the ported TB? Would you replace it with the stock one to play it safe?
Fast Dalmation is offline   Reply With Quote
Old 09-17-2017, 07:47 PM   #23
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Absolutely! That's easy, only 4 bolts..
Old 09-17-2017, 08:16 PM   #24
ninetres
ninetres's Avatar
Nonsense isn't a very good descriptor. It's just a data point that's not important to some (you, others).....and is important to some (me, others). This post wasn't meant to claim any sort of superiority, just to share my experience and thoughts on the product.
I wouldn't even consider yanking a plastic fitting out of the stock until with metal pliers....let alone destroying the clamp. But that's just my preference. Yours may vary.
Old 09-17-2017, 08:21 PM   #25
TheElementalCashew
TheElementalCashew's Avatar
Drives: 2017 ZL1
I'm with you, the clamp was really easy to remove, and should go right back if I need to.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325)
Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq
TheElementalCashew is offline   Reply With Quote
Old 09-17-2017, 08:26 PM   #26
Toons
Speed Racer
Toons's Avatar
Drives: 2023 ZL1
This is my second Camaro with a CAI and went with Roto Fab this time. Why? Because the whole dealer warranty concern was BS here, I never had a moments problem with service on the 2010, and in fact always told the advisor not to flash the tune because I had a custom job. They were more fascinated with the whole mod setup, headers, etc than worrying about what I had on the car aftermarket. Now did I blow the engine or transmission? Nope it's a good product. I think the worry is silly unless you are the 1 in 10,000 that drops an engine.
Toons is offline   Reply With Quote
Old 09-18-2017, 07:02 PM   #27
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
No option for one without! Was 1,200 now reduced to 661
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 09-18-2017, 07:17 PM   #28
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
looks great op, but it looks like it would be more of a hot air intake. those lt4's radiate a ton of heat, and that intake has no lid.
soloknight6 is offline   Reply With Quote
