Old 09-01-2017, 09:43 AM   #15
Captain Obvious
^Name^ | Things I Say -->
Captain Obvious's Avatar
Drives: 2016 2SS Convertible, Hyper Blue
I have a 2015 Durango R/T that has auto-leveling. I'll tell you from experience driving both that car and the 2016 2SS, the Camaro does not have auto-leveling. It's pretty obvious when the Durango is adjusting. And super cool.
I also miss Adaptive Cruise, which the Durango has and the Camaro doesn't. Chevy leaves out some pretty obvious options on some of their vehicles - my buddy just got a 2017 2500HD Denali, and the thing doesn't have adaptive cruise either, or even pushbutton start!
Captain Obvious is offline   Reply With Quote
Old 09-01-2017, 11:54 AM   #16
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Please do not duplicate threads. And please do not post threads in the 1LE subforum for things that are not 1LE specific.
Threads merged
-DG
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 09-01-2017, 12:26 PM   #17
solarstingray
Drives: 2014 c7 corvette and 2017 camaro ss
man I miss my Volvo s60 r design headlights, xenon, with active bending, these headlights suck LOL
solarstingray is offline   Reply With Quote
Old 09-01-2017, 07:16 PM   #18
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Threads merged
-DG
I stand corrected !
Thanks for merging the threads
Old 02-10-2022, 05:46 PM   #19
twoballscrewball
Drives: 89 Iroc Convertible, 2017 2SS Fifty
I know this is an ancient thread, however I searched for "camaro auto leveling headlights" and this came up first.
My 2017 Camaro (2SS) has a fuse (F38 in the engine compartment) that when I look it up says "Headlamp Leveling" I was troubleshooting a separate issue and meant to pull fuse 28, but pulled fuse 38 instead. When I plugged it back in, you can definitely hear mechanical noises from the headlight area.
I am going to go back out after dark with the lights on and pull the fuse, then plug it back in and watch the lights.
twoballscrewball is offline   Reply With Quote
Old 02-10-2022, 06:50 PM   #20
twoballscrewball
Pulled and reinserted the fuse with the lights on, nothing happened.
Old 02-13-2022, 10:38 AM   #21
JD64
JD64's Avatar
Drives: '19 Camaro ZL1 A10 Riverside Blue
My 2019 ZL1 has them, here are the calibration procedure and sensor replacement for the front and rear.
2019 Chevrolet Camaro V8-6.2L SC
Suspension Position Sensor Calibration
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Alignment Sensor Testing and Inspection Programming and Relearning Suspension Position Sensor Calibration
SUSPENSION POSITION SENSOR CALIBRATION
Document ID: 4310963
Calibration Criteria
Note: Remove any excess weight and do not sit in the vehicle during the headlamp leveling sensor learn procedure. Any additional weight will cause the calibration of the front and rear suspension position sensors to be inaccurate and affect the operation of the headlamp leveling system.
The headlamp leveling sensor learn procedure must be performed after a suspension position sensor has been removed/reinstalled/replaced, or if the headlamp leveling control module has been serviced. The learn procedure will set the front and rear suspension position sensors home value. This value is used by the headlamp leveling control module to determine the movement of the front and rear suspension systems. The headlamp leveling control module compares the information from both suspension position sensors and adjusts the headlamp leveling as needed.
Calibration Procedure
Ignition ON/vehicle in Service Mode.
Install a scan tool.
Navigate to the Configuration/Reset Functions menu of the Headlamp Control Module.
Select Configuration/Reset Functions.
Select Headlamp Leveling Sensor Learn procedure and follow the directions displayed on the screen.
Front Suspension Automatic Forward Lighting Position Sensor Replacement
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Alignment Sensor Service and Repair Removal and Replacement Front Suspension Automatic Forward Lighting Position Sensor Replacement
FRONT SUSPENSION AUTOMATIC FORWARD LIGHTING POSITION SENSOR REPLACEMENT
Document ID: 4176347
Callout Component Name
Preliminary Procedure
Front Wheelhouse Splash Shield Replacement
1 Front Suspension Automatic Forward Lighting Position Sensor Nut
Caution: Refer to Fastener Caution.
12 Nm (106 lb in)
2 Front Suspension Automatic Forward Lighting Position Sensor
Procedure
Disconnect the electrical connector.
Using an appropriate tool, separate the ball and socket.
Rear
Rear Suspension Automatic Forward Lighting Leveling Position Sensor Replacement
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Alignment Sensor Service and Repair Removal and Replacement Rear Suspension Automatic Forward Lighting Leveling Position Sensor Replacement
REAR SUSPENSION AUTOMATIC FORWARD LIGHTING LEVELING POSITION SENSOR REPLACEMENT
Document ID: 4176326
Rear Suspension Lower Control Arm Cover Replacement
1 Rear Suspension Automatic Forward Lighting Leveling Position Sensor Nut
12 Nm (106 lb in)
2 Rear Suspension Automatic Forward Lighting Leveling Position Sensor
Procedure
Using a hammer, gently tap on the sensor stud to disengage the splines on the stud.
Remove the rear suspension automatic forward lighting leveling position sensor from the keyhole slot.
JD64 is offline   Reply With Quote
