Old 08-24-2017, 09:36 PM   #15
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Some of the composites in tire shine will cause this discoloration. if that is what your using you my want to try another brand.
1hprush is offline   Reply With Quote
Old 08-25-2017, 09:11 AM   #16
Mighunter
Drives: 2017 Summit White 2SS
I'm guessing it's too late, can't get them clean
Mighunter is offline   Reply With Quote
Old 08-25-2017, 01:30 PM   #17
obarry13
obarry13's Avatar
Worse comes to worse, take a low grit sandpaper and wet it and slowly scrape a layer of the rubber off. I had a similar problem and that fixed it.
obarry13 is offline   Reply With Quote
Old 08-28-2017, 02:12 PM   #18
Mighunter
i used a white sharpie. Its more like paint than a marker as you have to press the tip down to get the stuff to flow. It actually turned out pretty good considering how brown they were. I'm going to just keep this up till the tires need to be replaced.
