#15 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
You requested 1LE decals?
#16 |
![]() ![]() ![]() Drives: Red Hot track candy Join Date: Oct 2009
I wish. Here is the first time:
https://photos.google.com/share/AF1Q...ExM0FxN204SmpB And if you think that is bad...here is the second time: https://goo.gl/photos/FsiBv7y3XZ3UABRy9
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
#17 |
![]() Drives: 2015 Z07 2017 ZL1 Join Date: Aug 2016
#18 |
@zle_blackwing
Did you price OEM ZL1 1LE calipers?
#19 | |
![]() Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
#20 | |
![]() Drives: 2017 ZL1 A10 Nightfall Gray Join Date: Jul 2017
#21 |
Drives: 2011 procharger ss Join Date: Sep 2015
We have the zr1 color matched color in stock if you were looking to get them done.
However at the moment I do not have cores for the 2017 zl1. They are over $2000 and without charging for a core exchange it takes a while to make up the cost. Turnaround time is under 4 days at the moment. Thanks, Kevin Last edited by TPH Coatings; 08-25-2017 at 01:52 PM. |
#22 | |
Most track days my calipers are smoking for 10 minutes when I pull off... If you do a set and they fade I will refund the cost.... Also Madison Powder Coating is TPH coatings, I just changed the name in January from TPH Coatings which was operating under TPH INC. -Kevin |
#23 | |
![]() What's the turn-around time? I'll send them in next week. Honestly, that is the best 'stand behind your work' statement I've seen in a long time.
#24 |
Yes, it is blistering off. The first picture was from OEM rotors and pads. The second was a combination of RB rotors and track pads as well as OEM rotors and track pads. Obviously the second repaint was not to the quality of the OEM. I was advised that the coating was good to 1200 degrees.
#25 |
About 4 days right now. I'm interested to see if yours will hold up to the heat. Sort of a destruction test... My 5th gen is only 650hp but heavier and the old 6 pistons held up and the new 6th gen zl1 have new fronts but the same old rears with a bigger offset for larger rotor.
