Old 08-21-2017, 05:28 PM   #15
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by mr965 View Post
I've tracked mine 3 times so far. The last time with the Moreno camber plates. I really feel the softness of the springs. My plan is to stiffen the springs but I am not knowledgeable in programming the DSC. Is it a steep learning curve?
Do you have any previous damper curve tuning experience or chassis calibration experience? The GUI itself is very easy to navigate, the big thing will be using your wisdom to apply to the settings.
Of course there will be a rational performance limit with the stock springs, and also another with the dampers themselves. This is where you'd work with DSC to go to their Tractive damper setup and dictate your spring rates accordingly.
Old 08-22-2017, 05:48 PM   #16
mr965
mr965's Avatar
Drives: ///M3
Great points Ryephile. Thank you!
mr965 is offline   Reply With Quote
Old 09-10-2017, 05:24 PM   #17
juice3
juice3's Avatar
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V
Was there anything else done to your car at the time of this video?
juice3 is offline   Reply With Quote
Old 09-10-2017, 07:24 PM   #18
lmcgrew79
lmcgrew79's Avatar
Drives: '17 Zl1, '16 Viper ACR, '15 CLA 45
Only brake fluid.
lmcgrew79 is offline   Reply With Quote
Old 09-12-2017, 06:16 PM   #19
juice3
juice3's Avatar
EDIT: Sent Tom an email. I'm going to see if this and a track alignment will help me brake into the 1:20:00's
Old 09-12-2017, 10:11 PM   #20
lmcgrew79
lmcgrew79's Avatar
I don't run summit very often, but i would imagine 1:20.xx may be pretty tough on the stock tires in general, the dsc and alignment should help but not sure if it will knock off a full 3 seconds. Do you have any video or data?
