#15 |
![]() Drives: Summit white 1le ss Join Date: Feb 2017
You can monitor your boost with an aeroforce gauge with out doing all the wiring
#16 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
When Ted tuned my car he had me install a new GM 3 bar sensor. I wonder if that one will let me read boost via OBD. Currently, I have an external Map 2 sensor from Aeroforce tapped into the procharger bypass valve manifold.
#17 |
The stock map is 3 wires, the 3bar sensor is 4 wires. The 4th wire is pigtailed into the OBD2.
Analog reads right off vacuum or boost, visa tube (my case) or another sensor. To read boost, I am told you need the 4 wire, 3bar Map. I have both with the 3bar map (OBD2 and analog). With the P3gauge. |
