Old 08-11-2017, 12:31 PM   #15
slick3
Drives: Garnet Red - 20 ZLE
Originally Posted by seanblurr View Post
Ok, so the "zl1 fenders are wider" are simply because the mounting brackets push them out? So in a sense... they are wider?
slick3 is offline   Reply With Quote
Old 08-11-2017, 12:58 PM   #16
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
If thats your way of looking at it that's fine, but by putting on some spacers your stock SS car can have the wider fenders too.
2SSRS@Gen5diy is offline   Reply With Quote
Old 08-11-2017, 01:44 PM   #17
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I'm just messing around.
seanblurr is offline   Reply With Quote
Old 08-12-2017, 08:01 AM   #18
The_DarkKnight
Drives: 2018 ZL1 1LE
I am so confused, are the part numbers the same for the ZL1 and ZL1 1LE fenders? are the part numbers the same for ZL1 fenders and regular Camaro Fenders? So a bracket makes them wider by distorting the metal slightly or mounts them more angled giving the impression of width?
The_DarkKnight is offline   Reply With Quote
Old 12-27-2018, 09:57 PM   #19
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by slick3 View Post
@Gen5DIY, Have you guys made any progress on making a kit for the SS to move the fenders out?
Yes, our C&C guy is working on that next, we have spent over 40K on a new line of C&C parts that are coming out in time for next year, so look for it soon, website will be ready end of the month.
Any updates on this?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 12-27-2018, 10:26 PM   #20
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Matt Farah is pro Mustang and his fat ass bounces on a flat surface in the 1LE. I don't believe what he says. Maybe 70% correct.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 12-27-2018, 10:59 PM   #21
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Summary:
Fender mold = same
Fender mounting = NOT same
What we dont know is if there is any secondary process done to alter "molded" part to achieve desired look besides modified mounts, which seems far too simple solution.
So.. who has 3D laser scanner handy ?
ing for grip.
http://www.motorsportsne.com/
Old 12-28-2018, 12:10 PM   #22
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
The ZL1 and other Camaros have 2 different part numbers for the fender. I think the mounts are the same on the stock cars and the difference is in the actual sheet metal. I have looked at them very closely due to an incident and it appears the ZL1 fender flares out more than the other Camaro fenders. It is so hard to tell with just your eyes, but I took measurements from fender to fender across the hood and also from hood to edge of fender lip. Measurements were identical across the hood, but the ZL1 fender sticks out further from the hood to the lip.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
17CamaroZL1 is online now   Reply With Quote
Old 01-02-2020, 11:44 AM   #23
vtirocz
vtirocz's Avatar
Gen5diy,
Old 01-02-2020, 12:46 PM   #24
Hazardousmutant
Hazardousmutant's Avatar
Drives: 2018 Camaro
The ZL1 and ZL1 1LE use the same wider fenders all other Camaro models use the non wide fenders. Here are the part numbers to clear up the confusion.
ZL1/ZL1 1LE
84326265- left fender
84326264- right fender
SS/SS 1LE/LT/LS
23221297- left fender
23221296- right fender
Hazardousmutant is offline   Reply With Quote
Old 08-06-2022, 10:32 AM   #25
JSH
JSH's Avatar
Drives: '20 ZLE
As you can see the mounts look alike but that front one on both the fenders is not the same there moved some .7+ , all the wider is at the bottom where it bolts to the car, the fender is rotated out at the bottom and only a small amount, from where the fender meets the door its 0" then goes out to .24 at the start of the wheel well, from there its goes to .7+ at the point where the bumper meets the fender and that is only at the bumper not at the hood line.
This puts to bed the "ZL1 1LE is wider" myth used here often.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 08-06-2022, 08:23 PM   #26
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
ZL1 and ZL1 1LE fenders are exactly the same. SS fenders are different
