#15 | |
![]() ![]() ![]() ![]() ![]() Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
#16 |
Nope, low 11's is not fast enough. The ones that gone faster then 10's are heavily modded. I want to see one in the 10's with just a drag pack or something close to stock. It will happen this fall.
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 A10 Join Date: Nov 2008
ZL1::J-E-T-S JETS JETS JETS |
#18 | |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
No. Once you drop the air pressure low enough to turn on the low tire alert, all the PTM options are disabled. No PTM, line lock, launch control, or any of that. I tried a launch with 26 psi like the manual suggests, and is about the lowest you can go before everything gets disabled, and I can get a better 60' by dropping the air. Plus I've yet to figure out a launch control setting that will give me as good a time as just launching the car myself.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#19 |
#20 | |
#21 |
I'll try to get what I have on youtube tomorrow and post links. Unfortunately, I mostly just have the PDR videos because my dad was also running his car. My dad did manage to get my last pass on his phone, so at least I have one from outside the car.
#22 |
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2009
Awesome times!! Congrats! It looks like I have company in the quest to be able to run 10s on street tires
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
#23 |
![]() Drives: 87 GNX 87 Turbo T '13 CTS-V Join Date: Apr 2013
OP is just trolling. That's what he does.
1987 Buick GNX
1987 Buick Turbo T 2013 CTS-V Coupe |
#24 | |
![]() Drives: 15 ZL1 red hot A6, 17 ZL1 Black A10 Join Date: Nov 2015
#25 |
#26 | |
#27 |
![]() Drives: 2017 ZL1 Join Date: Jun 2012
#28 |
I'll have to try it again sometime then. Maybe there was another reason I couldn't get into PTM that day. I used PTM and line lock the night before my first "prepped" track day running 26 psi in the rears. The next day during a private track rental for the KY True Street crew that my dad runs in, the first thing we did was lower the air to 18 psi in the rear, and after that I couldn't use line lock or launch control. It gave me the launch control disabled message. Maybe I was still able to choose the PTM setting and just not able to use line lock and launch control. I don't remember now, so I'll try it again soon.
