Old 07-31-2017, 08:36 PM   #15
USP45
Drives: 2017 ZL1 A10
Originally Posted by ADM PERFORMANCE View Post
I was out of pocket today.
All orders ship tomorrow.
Thanks
Andy
Good deal, just ordered. Thanks Andy
USP45 is offline   Reply With Quote
Old 08-01-2017, 10:54 AM   #16
ADM PERFORMANCE
Drives: Anything I want
Originally Posted by travislambert View Post
I know a little bit about that...
Attachment 888395
That's a messy way and still no ability to check the level.
Also a note - The factory pumps have a load sensing device in them that can tell if there is proper coolant flow going through them,if by chance you do not have proper amount of fluid or air in the system the pump will sense this and shut down. The intercooler pump does not turn on until the car has been running 10 sec(factory tune) and is at operating temps,IT IS ALSO A SOFT START UP.
It is very important that you verify flow once you finish installing the upgraded reservoir.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 08-02-2017, 06:55 AM   #17
ADM PERFORMANCE
All orders shipped
Thanks for all the orders guys,please feel free to coment once you get the parts installed.
Andy
Old 08-03-2017, 06:01 AM   #18
ADM PERFORMANCE
Since this is new to market
We wanted to let you guys know that we will have instructions in the near future for this product,just currently working on them.
For now here is a basic pic of how the parts bolt up.
Old 08-03-2017, 06:05 AM   #19
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
easy enough...I should have mine today. That looks like the reservoir included with the aftermarket superchargers like the Edelbrock E-force.
Old 08-03-2017, 10:14 PM   #20
Stephen12ZL1
Drives: '21 ZLE A10
Mine arrived today and I plan to install the unit tomorrow. It should be very easy and the above pic is a huge help.
Old 08-03-2017, 10:55 PM   #21
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
It's a Magnuson reservoir. I plan on putting this reservoir on my E-Force for the exact same reasons ADM is doing it for their LT4 supercharger setup.
Atomic Ed is offline   Reply With Quote
Old 08-04-2017, 08:55 AM   #22
Stephen12ZL1
Drives: '21 ZLE A10
How about one more pic of the front connections for total clarity? I can guess...
Old 08-04-2017, 03:38 PM   #23
Stephen12ZL1
Drives: '21 ZLE A10
looks like hose connecting the top of the intercooler pump to the manifold needs to be removed...the rearmost one with the vacuum bleeder connection. It has a little purple clip that must be removed first. The lower connection at the intercooler pump has a constant tension clamp. Remove this hose and store in a safe place. The intercooler reservoir may be mounted now on the strut tower brace location with the included hardware and the factory brace bolts. The front/lower nipple on the reservoir is for the new hose that has a 90° with no purple clip connection...go from the top of the intercooler pump to this front/lower nipple. The rear/top connection is for the return hose that has the purple clip connection on the water manifold end. Route as the pic above shows. Make sure routing of the hoses doesn't interfere with the engine belt or anything hot like the exhaust manifold. Place hose bracket as the above pic shows. Tighten worm gear clamps and refill system. Use black nylon tie straps to ensure clearance around everything. Check for leaks!
Old 08-05-2017, 05:39 AM   #24
ADM PERFORMANCE
Now just add pics and your hired. Nice write ups as usual
Old 08-07-2017, 10:26 AM   #25
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
Yea, few pictures of the finished product install would be good. I am thinking about this but want to see how it looks after the install. I am also thinking about getting the 5th GEN ZL1 fill assy and cap and use that.
tnspd is offline   Reply With Quote
Old 08-07-2017, 03:37 PM   #26
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
Keep us posted about instructions. I'm not a total dunce but some guidance would be appreciated.
BSR-1 is offline   Reply With Quote
Old 08-07-2017, 08:03 PM   #27
Stephen12ZL1
Drives: '21 ZLE A10
OK...just finished the install and it isn't scary at all. I took a bunch of pics but somehow my stupid phone doesn't show all of them in my gallery. I would recommend removing the air filter cover, filter, and box for easier access to the top hose of the intercooler pump. My top hose clamp was positioned in such a way I could not remove this hose without removing the air filter/box assembly. This clamp is glued to the hose so it requires a firm squeeze to the clamp limit then a firm pull straight up to remove the hose end. The other end of this hose is simple as the purple clip needs to be removed with a pick or small screwdriver then pull gently to release from that location. Have the new hose with purple clip handy and quickly click the end there and attach loosely to the new reservoir to contain the small mess of coolant.
Old 08-07-2017, 08:06 PM   #28
Stephen12ZL1
Drives: '21 ZLE A10
this hose is the one:
