#15 | |
Drives: Anything I want Join Date: Oct 2008
We also utilize the pre cooler in the driver side fender well. So technically speaking we have 2 heat exchangers and 2 intercoolers. We sent it out with 549 and 597 to the tires. The best pull was cooled off at 563 rwhp and 607 tq This is our $4995 package plus a rotofab intake on 93 octane fuel https://lsa-conversion-store.myshopi...ger-kit-625-hp |
#16 | |
You need a lot of parts to do the job correctly - Here is the basics https://lsa-conversion-store.myshopi...ower-no-blower We have everything in stock - https://lsa-conversion-store.myshopi...formance-parts |
#17 |
![]() Drives: 1973 z28 Rs, 2018 SS 1LE Join Date: Jun 2017
Is there any upward potential from here or would it be time for a new blower?
2018 HBM SS 1LE Built 7/26: Black emblems, Smoked reflectors/lights, Dimple magnetic drain plugs, Carbon rock guards, Carbon fuel door, Elite Engineering Catch-can, BMR strut-brace,
#18 |
Can't beat this price im tempted.
#19 |
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
So Andy, does this include everything needed for the complete build? Including all bits and pieces, intercoolers, the pre-coolers, installation manual and software? Like a typical complete kit?
#20 |
![]() Drives: 2017 fifty camaro Join Date: May 2017
I live in frisco. May have to look into this. Is the 1 year 12,000mile warranty the entire motor or just the work? Is there anymore upgrades to increase HP or is it a complete change out?
#21 |
Sparky
Drives: 2017 50th Coupe / 2017 ZL1 Join Date: Mar 2017
#22 | |
Sparky
Oh my! Got to let her loose last night! I thought her name would emerge as "undercover angel" but she told me last night it's Nasty Girl!
Roughly the same power level as my ZL1 but is much more violent (in a fun way!). Difference in tuning for the compression and cam profile I gues. Definitely Nasty, feel more beastly then the ZL. Mark Quote:
#23 |
![]() Drives: 2002 Camaro SS Join Date: Jun 2012
Nice numbers!
2017 1SS Hyper Blue M6
2001 Ford Lightning |
#24 | |
Considering they are all OEM Parts ,its pretty much a solid build. Last edited by ADM PERFORMANCE; 08-04-2017 at 07:58 AM. |
#25 | |
No tune. We have photos of the components going together for reference. The rest of the parts are complete(bits,pieces,new center intercooler,precooler(uses original precoolers just like ctsv and zl1,comes with all the proper hoses) |
#26 | |
I have 1 customer that makes 720 rwhp with one on E85,Cam,Stock Manifolds,Downpipes,Stainless works exhaust,Rotofab Intake,ADM Pulley and 14 psi boost,Wiseco Forged Pistons. |
#27 |
Here is what it is
- TVS 1740 High output roots supercharger
- Weighs 23 pounds less than the LS9 2300 - TVS1740 Front-Inlet Front-Drive rotors, utilizes the same Eaton technology as the Corvette ZR1 LS9 - Provides cooler discharge temperatures than comparable twin-screw systems due to design - Advanced high-flow inlet forward design - The heat exchanger has 15 fins per centimeter—that’s 50 percent higher density than on the LS9. So even though it’s 24 percent smaller, the intercooler rejects 10 percent more heat than the LS9. dual-pass charge-air-coolers utilize with less restriction than LS9 2300.On a typical 68-degree day, the discharge air from the supercharger can reach 248 degrees. By the time it passes the heat exchanger, those charge air temps are down to less than 120 degrees. - Designed to minimize noise Better air-handling characteristics than comparable superchargers - More power in a smaller package - Internal Bypass Valve virtually eliminates parasitic loss (uses less than 1/3 of a horsepower at 60 mph) - Delivers a proven increase in real world "under the curve" power - High thermal efficiency - Redesigned inlet and outlet ports specific to LT1/LT4 - Utilizes all factory "push-lock" connectors - Displacement on demand hardware retained for improved fuel economy - Components have been independently tested to GM’s specification - Only requires an oil change every 80,000-120,000 miles - 1-year/12,000 mile warranty supercharger - Standard 1-year Limited Warranty on electronics - Price does not include install or tune -In house installation and tune only - $1595.00 on most cars |
#28 | |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
The build combination is as follows: Vengeance Racing LT4 CNC ported cylinder heads Vengeance Racing Stage III camshaft Vengeance Racing cold air intake system Vengeance Racing flex fuel sensor kit AlkyControl dual nozzle methanol injection system Kooks Headers and Exhaust longtube header system STOCK LT4 short block STOCK LT4 throttle body and supercharger STOCK heat exchanger system STOCK clutch" https://www.facebook.com/VengeanceRa...27?pnref=story
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
