Old 08-02-2017, 07:11 AM   #15
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by Hyperlinkblue View Post
So theres a new table in hp tuners?, what exactly can you do with FPCM?
Yes, we can change the fuel pressure slope.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-07-2018, 12:56 PM   #16
Want1
Drives: 2017 Camaro SS 1LE
Another great read!
Thanks Ted!
Want1 is offline   Reply With Quote
Old 04-08-2018, 05:25 PM   #17
JANNETTYRACING
Originally Posted by Want1 View Post
Another great read!
Thanks Ted!
My Pleasure.
Old 04-10-2018, 12:14 AM   #18
Drsagacity
Drsagacity's Avatar
e85
Originally Posted by JANNETTYRACING View Post
My Pleasure.
Ted,
Sorry, but stupid question. I am tuned right now and planned to run on 93...if I make the switch to be able to run e85, I can still run 93 also, right?
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 04-10-2018, 07:19 AM   #19
JANNETTYRACING
Ted,
Providing you have the fuel supply, add a flex fuel sensor, tune it for flex fuel.
Yes sir, the definition of Flex Fuel means you can run 93-------E-85
Old 07-19-2018, 10:02 AM   #20
JANNETTYRACING
Bump for discussion.
Old 07-20-2018, 09:02 PM   #21
zepol9
Drives: 2016 Camaro 2SS NGM
Ted assuming just adding a whipple what else do you suggest to either replace or go with it ?
zepol9 is offline   Reply With Quote
Old 07-20-2018, 09:12 PM   #22
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
Ted, i plan on going whipple in a few months but have been dreading the full system upgrades as their isn't any concrete info i can find on a solid setup, Right now i'm Full Bolt Ons / NA.
I have the following MODS: Cold Air Inductions CAI, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Gen 5 LT1 VVT-3 Camshaft: 235/239, .645"/.635", 116 LSA +32% Fuel Lobe, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Delphi LS7-Style Lifters, TSP CNC'd Heads, Ported MSD intake manifold, Ported VMAX Throttle Body, MSD wires, Mishimoto Catch can.
My question is with the 1LE i have heard we have a intake ZL1/LT4 fuel pump so all i am needing is the LT4 Fuel Injectors and LT4 HPFP to run E85 with that setup? Would you recommend the LT4 injectors with 30% added fuel flow?
Not a doubt when i'm going whipple i'll be putting in forge internals to hold that power but my worry is more on the fuel system at the moment.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 07-21-2018, 07:19 AM   #23
JANNETTYRACING
LT headers w high flow cats as the stock cats are pretty restrictive.
A catch can.
A JRE Custom tune.
We are a Whipple Dealer please give us the opportunity to provide one for you.
Ted.
Old 07-21-2018, 08:23 AM   #24
JANNETTYRACING
Hello MP3BOOSTED, We are a Whipple Dealer and can provide the supercharger and answers to all your questions.
The fuel system info is concrete we have published all of our findings, You will need to add the LT-4 high pressure fuel pump, and injectors as well as a fuel pump voltage booster.
E-60 Seems to be the sweet spot give or take 5% for best power and stable fuel pressure at 9-10 psi boost.
Beyond that boost you will need to look at aftermarket high pressure fuel pump and injectors on E-60 or higher.
Feel free to call to discuss 203-753-7223
Thank you
Ted.
Old 07-21-2018, 08:42 AM   #25
Good stuff here...
Old 07-25-2018, 07:42 AM   #26
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
So with a Whipple on stock pulley, primary cat deletes, Rotofab, LT4 fuel system, Pump booster, and E78, will I have enough fuel supply? If not will the LPE big bore give me enough?
Old 07-25-2018, 07:47 AM   #27
JANNETTYRACING
Only Careful logging will tell for sure but I suspect you will be OK at 8-9 PSI boost.
Also the tuning is a Key player in all of this.
Ted.
Old 07-25-2018, 07:52 AM   #28
KingLT1
KingLT1's Avatar
Thanks. I was just curious since E78 is what consistently comes out of the pump here locally. It would be nice just to pump and go, but if I had to mix for E60 it wouldn't be a issue.
