#15 | ||
If you used the Microfiber Madness Dry Me Crazy, you wouldn't use waffle weaves any more. I only use my waffle weaves for doorjambs and cleaning glass now.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
#16 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Not much to quibble over though. Looks like a good towel.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
I would give it a try. Who makes that towel again?
#18 |
![]() Drives: 2017 Camaro ZL1 Join Date: Nov 2006
I've tried several towels like this and they don't absorb as well as the waffle weave towels do. Just my experience.
#19 |
Retired from Car mfrs....
My experience as well.........waffles also spread drying agents better, like aquawax or prima hydro.......
#20 |
My experience has been the opposite. Waffle weave towels do absorb well, but are thin.
Even the 500 gsm Microfiber Madness Wave Rider waffle weave I have cannot hold near the amount of water the DMC can. Also with waffle weaves, the potential for causing marring is much greater. Because of the thin pile, if a stray dirt particle comes between the towel and the paint, it has no where to go. With a plush towel, it is pulled away from the surface deep into the fibers away from the paint. Plush towels dry best when they are slightly damp versus bone dry. I usually mist the drying aid on the towel, which also helps to spread it thin. I've had my MM DMC for over 2 years now, and it still performs as new.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. Last edited by Joe M 2012 2SS; 07-20-2017 at 02:51 PM. |
