#15 |
I'm not worried about it, if the motor breaks I'll replace it with more cubes and better parts. I still feel like I might be able to get warranty on the tranny and rear diff since they've had trouble with both. Motor, NA its all mine. Its not the first time or the last that I'll mod a new car beyond the warranty. Its all good and with 93 octane I'm at about that 550 but with Meth and VP109 I'm probably at the 600-610. I'm only planning on going big pump just so I can run a smaller pulley (85mm).
#16 |
![]() Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
I love all the input guys. Thanks for all the insight. I'm definitely still supercharging the car, I was just curious if there were any regrets from those that have already done it.
Great community here by the way. I love it. |
#17 |
![]() Drives: 2017 Mosaic Black M6 1SS Vert Join Date: Feb 2017
For me it is because this is our 2nd car and I can afford to lose it if the engine explodes or whatever. But it was only in the last couple of years (I'm 40) that I could afford that. My previous cars only got minor mods like shifters, pedals, etc.
Sent from my SM-G935T using Tapatalk
2017 Mosaic Black 1SS Convertible M6 / MRC / NPP
Magnuson Heartbeat, Rotofab Previous: 2008 Corvette Convertible 2007 Pontiac Solstice GXP |
#18 |
NO regrets here Bro, and still building...LOL
#19 | |||
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Needless to say I still worry about this but to a slightly lesser degree that I did at first...
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#20 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
My car was number 10 in line at ADM performance. He has not got the engine out yet but he says he has seen a couple break either a ringland or piston and it always blows the front seal..... It felt like I only had 570 hp instead of 650.... if it wasn't leaking oil it ran pretty good on 7 cylinders. I'll post an update when it comes back together. I'm going to lower compression ratio, put in a forged bottom, get a cam with more fuel lobe and expect to make 800 whp on pump gas. I have plenty of turbocharger on this car.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
#21 | |
![]() Drives: 2016 2ss Join Date: Jun 2016
I've also done tons of research to get to my power level as safe as possible, it costs extra but it's a safety buffer...i.e. Just the right amount of sticky tires so i sont over do the torque on the drivetrain, fuel pump voltage booster to alleviate fuel pressure momentary drops, interchiller to reduce intake air temp which dramatically lowers knock potential...
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in. |
#22 |
Awesome keep us posted!
#23 |
![]() Drives: 1968 Camaro SS 350 Join Date: Nov 2015
What were the symptoms of this failure? Did you repair it yourself?
Needless to say I still worry about this but to a slightly lesser degree that I did at first...[/QUOTE] High speed pull on the freeway and the car started bucking. I immediately let off and shifted to 6th gear and heard a ticking coming from the motor. I pulled in to work, I work at a Toyota dealer, and popped the hood. The noise was definitely top end and i knew it was coming from cylinder 5 or 7. I suspected a bent push rod or collapsed lifter. Engine actually ran pretty good just a very very loud ticking sound... pretty recognizable valvetrain sound. I repaired it myself yes
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
The "Safe" HP number - this is uncorrected HP numbers right? I mean I'm at 6000 feet running corrected 620 WHP, that's corrected at 1.3 so actual is only 475-ish.
I assume we have to deal in "real" to the ground numbers here when talking about a safe HP number?
#25 | |
#26 |
I did not remove the AFM lifters. I replaced all four AFM lifters on the left bank. I also replaced the Lifter Oil Manifold per the GM TSB. If i run into another issue I will remove this system and cam the car. I believe the stock cam variable valve timing won't work without the oil manifold??
#27 | |
#28 | |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
