Old 06-26-2017, 01:17 PM   #15
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Regardless of what anyone's opinion is, the truth is if you go catless you will smell fuel odors. It will be at its worse at cold starts. You will smell it with the windows down while idling at a stop light. When I went catless in the past I would always have to leave my windows up and run the A/C in re-circulation mode to avoid the odor.
Some people have a higher tolerance for the odor so view are subjective. But having had multiple cars with catless setups and now my most recent cars have had catted setups, I much rather prefer cats. Plus it helps the environment. With technology today, power loss is pretty much negligible.
Old 06-26-2017, 01:46 PM   #16
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
There is no performance loss on going with cats. One of the FI guys is making 730 rwhp on the stock exhaust system.
If you insist with going with headers, then look at Dyntech headers that bolt up to the secondary cats and either eliminate the primary cats or have high flow primary cats that replace the stock primary cats.
Atomic Ed is offline   Reply With Quote
Old 06-26-2017, 02:08 PM   #17
TRich2SS
Drives: 2016 Camaro 2SS Summit White
Going catless does net more HP and trq either when simply using test pipes and especially when using headers. I don't think this is even a arguable point. If your point is that the relatively small gains don't justify the smell\impact on environment then that is up for discussion.
TRich2SS is offline   Reply With Quote
Old 06-26-2017, 02:54 PM   #18
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
I don't notice the smell when I come up to lights from my car or my buddies mustang. If your getting stuff out of the trunk you can smell it a little.
As for the rant....that makes it all sound much worse than it is. And I didn't buy a v8 to be friendly to the enviornment.....thats what my focus is for lol.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 06-26-2017, 04:06 PM   #19
SSDanny
Drives: 2017 Camaro SS M6
Originally Posted by marknagy13 View Post
Answer the question and keep your opinions to yourself.
The smell is not nearly as bad as he described it here unless you're at a standstill for like 20 minutes lol.
If you want more noise then go catless. If you want it a bit quieter then go high flo
Is the noise difference from catless and hi flows really that evident or is it just a slight noise difference?
SSDanny is offline   Reply With Quote
Old 06-26-2017, 04:44 PM   #20
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
As I said, some have a higher tolerance for what they consider smell. A majority of people are used to zero smell and have never owned a big cam catless muscle car. Stock cam cars are much more tolerable, but my advice is for those who never had a catless car before. Those people will most likely not like the smell.
Old 06-27-2017, 12:06 AM   #21
Atomic Ed
While it's true that there is some minor gain from using a test pipe (~10 hp with re-tuning) in place of the primary cat on the stock LT1 system, that gain all but disappears when you use high flow cats designed for headers.
https://ls1tech.com/forums/generatio...un-catted.html
It's pretty hard to beat the performance of the stock exhaust system on these cars. Particularly when considering the cost of headers and the install costs. But if your are going for the sound, headers do sound nice.
Old 06-27-2017, 01:36 AM   #22
TRich2SS
That thread is hardly scientific and at best it contains anecdotal evidence which basically amounts to random people throwing our random numbers.... Also, we don't have Ls1 engines so I am not sure that thread is relevant to this conversation about our 6th gens. In any case, I think it is really up to whoever is purchasing the system whether or not its worth it. I personally love my catless system. Sound is louder and on E85 there is almost no smell to speak of.
Old 06-27-2017, 10:35 AM   #23
somewhatdamaged
somewhatdamaged's Avatar
Drives: 16' 2SS M6
Great advice! I only ran a catless setup once on my old C5 Z06 Vette. I had bought some used long tubes, had the catless setup installed and drove home. The smell was not pleasant, I was not used to it. On that setup, I felt a loss of low end torque as well. As far as sound, I found the high flows to be less raspy as well.
somewhatdamaged is offline   Reply With Quote
Old 06-27-2017, 10:44 AM   #24
Atomic Ed
There were two posts of before and after dyno pulls, one stated zero gains and the other posted a 4hp gain on a 500 hp engine. Yes, these were LS1 engines verses our LT1 engines; does that really make any difference regarding headers and cat deletes? We'll let the OP decide.
Let's not muddle this point. That is, do not expect real performance gains by leaving off the high flow cats. You'll barely be able to measure it, if at all, on a dyno with back to back pulls.
if you want to leave off the cats for whatever reason, that's your choice, but don't expect noticeable gains in performance.
Old 06-27-2017, 11:18 AM   #25
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
The loss of torque was more likely due to timing not being optimal for catless headers. I had a catless longtube w/ x pipe setup on my C5 Z06 and I made more power everywhere on the dyno. Tuning is key.
Old 06-27-2017, 09:57 PM   #26
1badrwd
1badrwd's Avatar
Drives: 2016 camaro 2ss npp, A8
I have 1-7/8 long tubes without cats and its not bad. You do get a little smell sitting still for a few minutes but not bad at all. I've also followed my wife driving the camaro for 20-30mins a couple of times so i can vouch its not that bad when behind one on the road.
2016 2ss- CAI, Ported TB, MSD intake, StainlessWorks LT headers & full exhaust- no cats, HP custom tune.
M228 wheels, michelin pilot super sports 285/35/20 front, 305/30/20 back
To be American is to love the flag, women, and sports cars!
1badrwd is offline   Reply With Quote
Old 06-28-2017, 01:11 PM   #27
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
Originally Posted by cooden View Post
I always remote start it--love hearing that sound when I'm walking towards the car. I don't really notice any terrible smell.
Because you are a man
For those of us who have gone or will go FI, cats present a real concern for the increased heat. Red lights generally don't last more 1-3 minutes and it won't be a problem short term and it certainly isn't bad enough to melt all the snowflakes
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 06-28-2017, 08:51 PM   #28
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
If you run a supercharger on your Camaro and you want peak performance without melting the cats, guess what you have to do? Go catless. Don't get behind my car is what I would tell you.
I will say I have been shocked how many 6th gen customers buy offroad (i.e. catless) headers. On most newer cars, it is 75% catted. 6th Gen is more like 40%.
In terms of off road, only reason to do it is save money. Catted systems flow almost the same, and there is a very small difference in sound.
On a supercharged car, the regular cats will last if tuned just right. A crappy tune will kill them fast. If you want something more forgiving, the green cats Kooks offers flow even better and are rated to 900 HP.
http://marylandspeed.com/headers-c-2457_2458.html
MarylandSpeed is offline   Reply With Quote
