Old 06-18-2017, 04:14 PM   #15
nick_casper
nick_casper's Avatar
Drives: 16 2SS
Originally Posted by Atomic Ed View Post
Nick, I noticed your long term fuel trims varied quite a bit from bank 1 to bank 2 (-1.6 vis 3.1%). Any concerns there?
That does seem like a large difference. What would normally cause this?
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 06-18-2017, 04:18 PM   #16
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
Not sure. Maybe you should start a separate thread and ask some of the more knowledgeable members about the difference. Or ask Whipple?
Atomic Ed is offline   Reply With Quote
Old 06-18-2017, 09:46 PM   #17
laynlo15
Drives: 2022 Lt1 A10
What are your power enrich numbers. My initial fuel rail pressures were low and it was falling off about 5800. I fixed that and made another 40hp and my fuel rail pressure came back up to 2200 from about 1500.
Old 06-19-2017, 09:10 AM   #18
shinysun
Drives: 2016 Camaro SS
Fixed them
Thanks!
shinysun is offline   Reply With Quote
Old 06-19-2017, 09:15 AM   #19
shinysun
I searched many articles, but not clear yet.
LTFT affects on WOT or not?
If it affects, where is it coming from? As I know, STFT is 0% on WOT , which means no learn for LTFT.
As I understand , the driver side is leaner than the passenger side.
Old 06-19-2017, 09:28 AM   #20
shinysun
at low : 1.22
at mid : 1.24
at high rev : 1.25
my stoich number is 14.68
and commanded AFR is 12:1 ~11.7 around
btw, recently I put AFR gauge on my car and it showed 10:1~10:8
Too rich than I expected, so I reduced the PE numbers to 1.22 on the all rev and it made 10.8~11.5 :1 on the actually AFR gauge.
Furthermore , my rail pressure was back to 13Mpa from 11Mpa range (from 1600 to 1900 PSI). It is not enough, but better than before,.
Not bad result. I believe that I made my injectors sprayed the way too much due to some mis-calibration like MAF and it triggered the lack of fuel.
Are there any other guys having Whipple and checked AFR with the stock flash?
Old 06-19-2017, 11:29 AM   #21
nick_casper
Drives: 16 2SS
Originally Posted by shinysun View Post
at low : 1.22
at mid : 1.24
at high rev : 1.25
My wide band is in the mail. I'll post up some numbers once I get it installed.
Old 07-05-2017, 04:00 PM   #22
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
Hey shinysun,
I hope everything is looking better for you. If you don't mind could you tell me how you are data logging your ride? I'd like to do some logging on mine and just wanted to know what I need to do it? Just a heads up I have a MAC. You using a laptop/device/software?
Thanks
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
Old 07-05-2017, 04:06 PM   #23
laynlo15
Those are good numbers on the power enrich. Basically right on point with mine.
Old 07-05-2017, 04:25 PM   #24
brettman
Originally Posted by Joe's_cool_1le View Post
Hey shinysun,
Thanks
Hey Joe, I'm a MAC guy too. These programs, logging/tuning are for Windows (at least the HPtuner I had) couldn't use it due to old unsuitable computer. SO, my tuner prints the number for me.
brettman is offline   Reply With Quote
Old 07-05-2017, 05:25 PM   #25
Joe's_cool_1le
I do have access to other windows PC's but just not a laptop. So if I could log on a device uses a memory card I could then transfer that over to windows PC. ???
Old 07-05-2017, 07:30 PM   #26
shinysun
Hey shinysun,
Thanks
Hello,
I am using Surface 3 from Microsoft. It is quite nice for VCM program of hptuner.
Recently, Microsoft established Surface 5, so the price is relatively cheap.
Or, My recommendation is YOGA book with Window software. There are 2 types of YOGA book from Lenovo. Android and Window. Quite cheap, but powerful.
Old 07-05-2017, 08:03 PM   #27
Joe's_cool_1le
Hello,
Thanks. I guess I'll have to get one from work to test it out.
Old 07-06-2017, 11:01 AM   #28
nick_casper
Drives: 16 2SS
I bought a tiny 2-in-1 windows PC from Walnart for $64 to use in the car. It runs HP Tuners great.
