Old 07-09-2017, 01:37 AM   #15
1slowssm6
Drives: 2016 1ss m6 Camaro
if i could ever get a friday night off work that it doesnt rain i plan to pull the abs fuses and clutch dump at 5k and see what the car does,slowly releasing the clutch basically causes a bog situation,and my last outing with a 4k clutch dump resulted in a 1.8 60ft and a 12.1 in a stock ss on a slick,i think with a proper high rpm clutch dump on an m6 car on a slick a 1.7 60ft and dipping into the 11's is possible,im shotting for a 1.6 60ft on a 5k dump with suspension but we shall see.
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step.
Best 1/4 mile of 11.2@122mph
1slowssm6 is offline   Reply With Quote
Old 07-09-2017, 10:39 AM   #16
Fraxum
Fraxum's Avatar
Originally Posted by cwebster View Post
If you've had an ECM tune, the tuner may have programmed out the protection feature. Seems to me it's main purpose is to prevent warranty claims. If you've already voided the warranty with a tune there shouldn't be a problem.
Yes the ZL1 has beefier drive shaft and half-shafts at least. I think the diff might be stronger too. Still uses the TR-6060 tranny but it's the MJK variant instead of your MM6.
I also ran my SS 100+ runs stock. Lots of clutch slipping, lousy 60's (best 1.93 I think), and no nose dives. Any stock M6ers see this? Maybe its a 2017+ thing.
Old 07-10-2017, 01:16 AM   #17
BlaqWhole
Drives: 2017 Camaro ZL1 A10
Not sure what you mean by "just going off idle". All launches with the M6 require some combination of clutch and throttle. All combinations I've tried result in either wheel-spin or ECM intervention.
I took it that you guys are launching at a certain RPM. And I'm saying instead of that maybe try feathering it from idle.
Old 07-10-2017, 07:31 AM   #18
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
This is NOT a ZL1 only issue. Several of us ProCharged M6 owners have had issues getting the cars to launch hard. The best I've heard of is a 1.54 60' on slicks. I've been 1.75 60' on 28" Hoosiers. All of my TQ management settings are maxed out. Currently we're searching for the clutch protection parameters to "hopefully" allow us to really hit the tire. Since my car revs to 5K rpm in gear with the clutch depressed, I hold it there and slip the clutch out to get my best 60' times. I have yet to figure out where I can bring that down to allow me to just side ste the clutch.
There seems to be a whole bunch of stuff tied into these cars that keep us from trying to break parts.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 07-10-2017, 07:32 AM   #19
Cdflyer
Cdflyer's Avatar
I don't know about the ZL1 guys, but my ProCharger car will just do a 100' burnout with the slicks if I try to launch like this.
Old 07-10-2017, 07:35 AM   #20
Cdflyer
Cdflyer's Avatar
My car went 12.04 with a 1.77 60' when it was N/A. The very next pass I replicated the launch.....and snapped an axle. It was floored to 5K, with a quick, controlled release of the clutch. Dumping it resulted in a burnout.
Old 07-13-2019, 05:51 PM   #21
meSSohappy
meSSohappy's Avatar
Drives: 2018 ZL1 A10
My 2018 ZL1 A10 with custom tunes will pull timing at launch too. Cant get below 1.7 no matter what buttons I push or how I do burnout. I can see it in my tune. Pulls all the timing as soon as I hammer down. Tuner suggested pulling the Stab/TC fuses. Never mentioned the ABS fuse pull. Are they different fuses?
DAVENPORT STAGE 2 PLUS - 2" ARH ceramic coated headers - 3" ARH catless exhaust - Stock NPP mufflers - Kong ported SC - Katech 103 ported TB - Rotofab 5" Big gulp CAI - 22.5% lower pulley - ATI Harmonic balancer - Cordes SC expansion tank - MSD hi temp ignition wires - Koolsox spark plug insulators - custom tunes - 660hp/725tq pump - 713hp/763tq race
meSSohappy is offline   Reply With Quote
