#15 | |
![]() ![]() ![]() ![]() Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
#16 | |
retired badass
Im just trying to persuade guys to do it themselves, so what it takes you a weekend, at least you've still got $$$$ in your bank account for MORE go fast parts. Ill give you that though I am retired military, but while on active duty I did all my work as well. Shoot I even help people I don't know do installs just to save them the money. Just saying. (not trying to pick a fight) I just hate seeing people get hosed when it comes to labor.
2016 2SS M6 Black
Kooks 2in headers/full exhaust, Hurst short shifter, Dsx E85 kit, BMR solid engine mounts. Retired USMC |
#17 | |
#18 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I have a guide up in the DIY section for a Stainless Works full exhaust with headers. I can't imagine it being much different than the Kooks.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#19 |
![]() Drives: 2016 Corvette Z06 Join Date: Apr 2017
Header installs can be a pain in the ass. I haven't done it on a 6th gen but I've done 2 of them on a 4th gen and unless you have a lift and a friend it's going to be misery. The amount you need to lift the front end up to be able to get the headers out the bottom is significant and can be dangerous if you don't have the right tools/patience/time etc.
Just pay to have it done, unless you have an accessible lift and a mechanically inclined friend or 2. |
#20 | |
retired badass
I've never used a lift for any installs from headers to transmission swaps in any vehicle. I use truck jack stands, my car was up high enough to almost sit straight up under it. No friends to help and I did it all by my lonesome, to include a 12 bolt rear end swap and all. I'll admit the 4th Gen is and has some tight spots but perfectly doable and safe on jack stands. I spent more time making sure everything was safe a stable than installing parts. Truck stands can get you well over 22inches in the air and that's more than enough to do any install.
2016 2SS M6 Black
#21 | ||
![]() Drives: 2017 Summit White Camaro SS 1LE Join Date: Apr 2015
Hey Guys decided to bring up an older Thread so I don't get yelled at for not using the Search menu lol...
Just ordered my LT from Kooks and want to get it done with a few buddies on the driveway while drinking some beers (Best way to install anything) Wanted to know if you could share some pointers especially with the passenger side? I did this install on my 2010 and a few others so Ive got experience just wanted to know what I was getting into. Any other threads or write ups you guys can recommend would truly be appreciated.. Thanks Adrian Edit: Found this info for anyone else looking.. Quote:
http://www.camaro6.com/forums/showth...install&page=2
Rotofab Intake, Borla 60606 Midpipes, Corsa Extreme Axleback |
#22 |
Darth Martel
#23 |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
I used your write up when I did my kooks. Only difference is I took the starter off instead of the motor mount
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
#24 | |
#25 | |
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear. |
#26 |
I wish I can install these myself. I do have a 2 car garage but having 3 knee surgeries in 2 years kind of makes this impossible to do by myself.
Trying to find help and or a garage in NJ that won't rape me to install theses is very hard.
#27 | |
Next item is the E85 kit, plan is to buy it all and have it ready to go so I only have to tune it once..
#28 |
Texas Speed comes with the metal GM gaskets, and the extended wiring and the shorter stearing bolt- for $600 with off-road pipes or $850 for catted connection pipes...just saying lol
