#15 | ||
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Aug 2009
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab |
#16 |
Simply holding the traction control button for 7 seconds will turn everything off.
#17 | |
Thanks for the info. I did not know this worked in these cars. When I did this in my 2013 ZL1 the I had to tap it twice and hold it down, this car you must hit it once and then hold. Does any indicators come up on the screen? Thanks for the help.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
#18 |
Bring It
Are you going with a group or trailer or something? I thought the question about cooling with the hood open was silly at first because it was a stock car...now I'm trying to remember the last time I saw a stock car getting the full trailer queen treatment
![]() I've only been once and given the advances in this cars cooling I couldn't help wondering if it may cool down better idling than shut off completely (if someone didn't have fans, etc).
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
#19 |
![]() ![]() Drives: 2017 ZL1 A10 Join Date: Sep 2009
I don't put any fans on mine. But I always park it facing into the wind, with the hood open.
2017 ZL1
A10 Redhot with stripe |
#20 | |
When it's cool outside with a decent wind blowing, I pop the hood open and turn it into the wind. When it's warmer than 70 degrees out, it doesn't cool down fast enough to maintain consistency between passes. Believe me I love racing, but I want to run the quickest possible times when I run. It's a waste for me to run if the car is so hot it's going to affect the performance. Like I said before, it has a ton of coolers for the road course, but it means nothing when drag racing, IMO.
https://youtu.be/EyHtdH9XOkY https://youtu.be/Lcu41obbTf8 '13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight. http://youtu.be/yggIA3C_kkA 2014... back to stock http://youtu.be/spQLaTWbThs 2013... stock & RotoFab Last edited by big dave; 06-10-2017 at 03:43 PM. |
#21 | ||
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
What would be really cool for us drag racers, would be a method of circulating the coolants and running fans to cool the engine between runs, or at least the supercharger.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#22 |
1st Civ. Div.
Drives: Camaroless for now...RIP "Big SexZ" Join Date: Dec 2007
Great times guys....keep up the good work!!
Seems like a good thing to eventually have is some sort of interchiller for the drag racing folks for consistency.
Swift....Silent....Deadly
#23 | |
On my 2012 ZL1 I rigged up a switch that turned on the SC coolant pump and radiator fan at the same time. Worked great. Will eventually do the same on this car.
2017 ZL1
#24 |
That's along the lines of what I was thinking about. Did you put the switch under the hood, since you're going to be raising it anyway?
#25 | |
I would like to do this also.
#26 |
Yes. Just under the fuse box.
2017 ZL1
#27 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
As far as running the fan and intercooler pump go, you may be able to set this up with HP Tuners. I haven't looked at a ZL1 tune file yet, but I set up my Magnuson supercharged C6 to run the fan and intercooler pump after shutdown with warmer coolant temps. There was quite a bit of customizing possible. I'm guessing the same could be done on this car. I know some people might be afraid of flashing the ECU due to possible warranty issues, but I'd personally try this before adding a switch or modifying wiring.
#28 |
You all have pretty good ideas about different ways to cool the engine...but there may be questions raised as to whether the car is still considered stock. I don't want to deviate in any way from what the factory has given us. Cooling the intake and blower with a fan shouldn't effect its' stock status...at least I don't think so.
