#15 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
I would play around with the slip. From one end of the spectrum to the other. Also isn't ther a setting for the road surface? Might make a difference too. The problem is by the time you perfect it you'll need new tires. Lol.
#16 | |
![]() Drives: 2017 garnet red zl1 2022 AT4 HD Join Date: Nov 2016
So this morning I found a lot to try launch control out. I wasn't actually going though a full pull, but just figuring it out. So I set it to 1400 rpm and 10% slip. Brake pedal all the way down and gas pedal all the way down. Rpms did settle at 1400 rpms so that is working. So I let go of the brake and low and behold, it is the exact behavior that happens when I "warm" the car up. So I'm thinking it's definitely the torque management. It's insane that it really cuts that much torque when it wants to. |
