#15 |
![]() Drives: Burgundy camaro, 1LT Join Date: Mar 2013
I would love to know if there are any sensors instead of a camera that I can buy for the front.
#16 | |
![]() ![]() Drives: 2016 2SS, Red Hot, NPP, Nav, M6 Join Date: Jul 2016
That said, I would have preferred a front camera if the costing was similar and it was something easy for DIY. Curb alert installation was pretty easy. I have my sensor installed on my Sho n Sto mount bracket and did have some road debris kick up and break the sensor housing where the henge is. It stopped working and I found it just hanging by it's cables underneath the car. Can see the impact mark where something impacted it, like a rock or something. I have half assed super glued it back together for now until I figure out something besides buying a new sensor replacement at almost the cost of a new full unit! |
#17 |
![]() Drives: 2016 SS Mosaic Black Join Date: Jul 2012
What did it cost to add the curb alert?
#18 |
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
I am really interested in that kind of solution. A camera which works with the Nav-screen.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
#20 |
![]() Drives: car Join Date: May 2016
Interested and subscribed !
#21 |
Burningice, how's the system working out for ya? A lot of people are curious about the components used
Nick |
#22 |
Sorry guys been busy building my own Camaro parts company. The product that I am currently using is fighting me. I'm trying to see if it is a defective product or just a defective unit. I don't want to promote something that will cause everybody else headache. I will say that every time that I go into reverse and then shift to first gear to go forward the front camera triggers and is active up to 10 miles per hour. The problem that I am experiencing currently is that I cannot manually turn the camera on. Which isn't detrimental but would be nice. Also the product that I am testing allows me to put side cameras on as well that are activated when you hit the turn signal. It's a pretty nice feature.
#23 |
well hurry up. I need that shit now!!!
#24 |
Thanks for the reply, I'm anxious as welll. Not that it will help but I just scratched my rim on a curb at the gas station 15 miles from home after a 600 mile trip in one stretch
(been driving Ram's for the last 9 years)Nick |
#25 |
![]() Drives: 2017 1LT RS V6 A8, 2020 Fusion Join Date: Jun 2017
A local installer called NAV-TV and was told that the GM UNI-CAM KIT629 would be the correct unit to use with the 7" screen, even though it does not say so on their website. Can anyone actually confirm this works with the 7" screen??
#26 |
I would be willing to test this if nav-tv ever returned our phone calls. But apparently they are too busy. This other company that I'm testing out apparently is completely useless as well. It has been damn near three months for me to get a functioning product. I do not recommend this company.
#27 |
I have real experience with Navtool modul. I finalize installation last week. I have 2 line cam and 1 front cam. rear cam I deactivated. everything work fine but: modul work fine with can-bus, automatically shows cam after turn switch, problem is manually switch input video signal. Camaro don't have Menu button as have other Chevy cars( short press switch video signals from cams) . i must install individual button for switching video signals.manual switch on/off is working by long press Back button. second problem is that I have white 4mm line in right site of display when I try mirror iphone via hdmi interface. I asked support of nevtool about this issue, but they sad that it's question of hdmi signals no navtool modul. hmm:-(
#28 |
This is the same unit that I am trying to get to work correctly. Everything worked well for about 2 weeks and then the command by holding the back button 3 seconds no longer works. I was told I installed it incorrectly but there is no way that is possible. I could throw out that I am a mecp master technician and how many years of experience I have installing similar products but this is a literal plug-and-play install. No install splicing required if you are just adding a front camera. They have tried to shoot me two additional units but for some reason UPS has lost both units. I'm getting very frustrated with them. I have been doing this for several months now.
