05-26-2017, 09:49 AM | #15 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
I would say avoid the GM performance dampers without the lowering springs. Main differences are: 1) slightly increased rebound force 2) slightly reduced compression force 3) shorter length to properly align with the lowering springs. For stiffer suspension, I'd suggest taking a look into stiffer non-lowering springs and/or stiffer roll bars. Maybe even the 1LE suspension kit? https://www.summitracing.com/parts/n...UqQhoC6F_w_wcB
2017 SS 1LE.
05-27-2017, 08:43 AM | #16 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
the rebound force is basically what I AM looking for. and already running the BMR adjustable swaybars front and rear. def appreciate the info though... that, or some FE3 parts (1LE setup) might be the appetizer needed. just watched the Al Oppenheiser vid on the 1LE v6 release and he said the V6 came with the FE3 dampers and something about the springs... so now I'm wondering if the whole car comes with the actual SS springs AND dampers...
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
05-27-2017, 10:58 PM | #17 | |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
05-27-2017, 11:14 PM | #18 | |
And yes, everything I've read on the 1LE V6 is they used the complete SS suspension parts. Shocks/struts/bars/springs. I haven't read anything about bushings like the SS 1LE |
05-28-2017, 04:27 PM | #19 | |
Also, as Glen pointed out, I linked the kit for the 5th gen 1LE suspension kit I've seen other people get the 1LE suspension kits for their 6th gen SS Camaros, so I had just assumed that the 6th gen V6 1LE suspension would also be available as a kit. My bad!
2017 SS 1LE.
05-29-2017, 07:47 PM | #20 | |||
true... right now, if I did anything along that route, I'd have to grab a random vin and source out individual parts. no biggie though.
from this vid, start it at 7:31. Al O says its the cooling, suspension, and then says bushings, and cross axis ball joints. so i'm guessing the toe links and possibly the rear cradle bushings. as far as swaybars, already have the BMR adjustables front and rear. the rear cradle lockout will be soon. Quote:
weight dealing with my car specifically isn't much of an issue (needing the lighter v6 versions due to lack of engine weight). at 375lbs I legit overcome that 200lbs weight savings over the v8. if you put me in your car, its the equivalent of 2 extra passengers. so if the v6 is normally 3600-3700 and some change, I legit put the car at or over 4000lbs. if anything, I maybe should upgrade to the SS springs to counteract the extra weight already in the car daily no worries about the 5th gen kit. all In good intentions, and def appreciate the help. like said above, I'll prob have to grab a vin and go parts hunting. not that big of an issue.
06-06-2017, 10:47 AM | #21 |
talked to bilstein again over the weekend they are coming out with a full line of goodies for our cars! oem shocks , performance shocks and coilovers etc
06-06-2017, 01:26 PM | #22 |
Cool stuff. Still no time line though, right?
06-07-2017, 12:54 PM | #23 |
he said third-fourth quarter and if i dont have coilovers on by then ill probably grab some lol
06-07-2017, 01:07 PM | #24 |
Drives: 2017 camaro ss Join Date: Jan 2017
Any word on Koni?
06-07-2017, 01:44 PM | #25 |
Drives: 2016 1ss Camaro Join Date: May 2016
i havent heard anything but i can try to reach out to them again for you guys if you want?
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
06-07-2017, 10:34 PM | #26 |
Still looks pretty high to me, mine is low and sits right on top of the tires. The shocks will not affect the ride height. The shocks will only react to road conditions, rebound, corning, etc. I went with the Phastek lowering springs on stock struts. I will change those out the winter a shorter strut/shock since its lowered 1.5 inches and will eventually cause some issues with the longer strut/shock. Love the way it handles and still hooks like crazy at the strip.
06-08-2017, 06:22 AM | #27 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
This is some great news... Didn't know bilstein was developing stuff for us
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
06-08-2017, 07:50 AM | #28 |
Drives: 16 ngm ss Join Date: Jan 2017
I had emailed Koni back in April.
" Thank you for your interest in KONI shocks. The ‘16+ Camaro sport yellow shocks are currently in the early stages for product development. The last update that I heard, was that Engineering is waiting for sample spring seat stampings to show up, in order to produce the first set of prototypes for test fitting. Once fitment has confirmed and completed, we can then begin the shock valving development, and road testing of the damper. Unfortunately, until the prototypes and testing are complete we will not have an expected availability date for the products release. You can keep up with our most current applications at www.koni-na.com." |
