Old 01-07-2018, 01:42 PM   #15
kkriskal
kkriskal's Avatar
Drives: 2018 2SS Triple Black Performance
Originally Posted by BMWM.D. View Post
This is the ZL1 section, and we have a different engine. So not apples to apples. But every modern small block I’ve owned has had a bit of a rough idle. It’s just how they are. There’s also a cat warmup routine (that usually retards the timing) that can make the idle rougher.
I’d say what you’re feeling is totally normal, and there probably isn’t anything the dealer can do about it. You can probably reduce or eliminate it with tuning software (bump idle speed, turn off catalyst warmup, etc.), but obviously there are consequences to that.
Hello BMWM.D, I am sorry, new to this forum so did Not realize until now that it was ZL1 section. However, thank you for the clarification, if it Normal then I don't want to do anything, it actually sounds cool like the old age carb models especially with the Track mode exhaust option. Just wanted to make sure it was normal, thanks again for your clarification.
kkriskal is offline   Reply With Quote
Old 01-07-2018, 02:29 PM   #16
CRF8
Scenic City Camaro
CRF8's Avatar
Drives: 2022 Camaro ZL-1 /1974 Firebird 400
Originally Posted by CRF8 View Post
I’m no expert, and have no mods, but I do have a rough idle. No codes
Sorry didn’t see it’s the ZL1 section, I’m on my
Phone and that column is hidden unless I scroll
CRF8 is offline   Reply With Quote
Old 01-07-2018, 03:22 PM   #17
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Originally Posted by NightfallZL1 View Post
Ok so I didn't notice this at first but I seem to have somewhat of a rough idle you can feal it sitting in the car in park. I'm not sure if this is because of power/large camshaft or something is wrong. No check engine lights are on.
Normal. Mine does this as well (1900 miles) and also has an regular interval miss/skip. I haven't gone through the trouble to identify the time interval between misses, it's at least a minute I think.
I had a 2000 Fat Boy that had a similar miss. Kinda quirky for both to do the same thing. While I am curious to know why in this case I'm not worried about it.
Old 01-07-2018, 07:23 PM   #18
kkriskal
kkriskal's Avatar
Thank you for your confirmation and feedback
Old 01-07-2018, 07:35 PM   #19
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
Totally normal... my 5th Gen Z did that too.
Same here MLEE on my 5G ZL1. Took it in teice and was told it was with in perimeters. My 2017 ZL1 is not like that.
KLR ZL1 is offline   Reply With Quote
Old 01-08-2018, 06:07 PM   #20
kkriskal
kkriskal's Avatar
Thank you, I am glad it is a known behavior and widespread.
Old 12-21-2018, 02:46 PM   #21
f.d
Drives: camaro
I have the same thing, I feel like there is a misfiring from the first day. 2018 Camaro SS Auto, brand new.
Now today it's just 2600 km.
I did scan for Idle, and it shows fast swinging +15 rpm to -15 rpm .
It’s never stable.
I forget what was the Idle rpm , maybe it’s swinging between 550 rpm to 580 rpm very very fast swinging.
No codes & no problems.
Sorry for bad English, I’m just trying to help.
f.d is offline   Reply With Quote
Old 10-05-2021, 05:35 AM   #22
adnan92
Drives: Camaro 2ss 2016
Im also having this issue i almost changed everything cam sensor,crank sensor, injectors, mechanical fuel pump, pcv, map sensor, maf, fuel lines , spark plugs and wires, and all procedures for cleaning throttle and fuel sys .
Sometimes i have hard shifting from 1st to 2nd and from park to reverse . No codes just Amplifier shorted circuit
adnan92 is offline   Reply With Quote
Old 10-05-2021, 07:46 AM   #23
JSH
JSH's Avatar
Drives: '20 ZLE
Yes, mine feels and sounds pretty lumpy
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 10-05-2021, 08:47 AM   #24
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Yes my 2017 ZL1 does it too which is totally stock with the exception of the RF CAI. I see no problem with yours.
Old 10-05-2021, 08:51 AM   #25
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
It's normal for GM small blocks. If it was misfiring past a certain threshold of what GM considers acceptable then you would get a check engine light. The ECU's are pretty smart so if there is a issue your dash is gonna light up.
Old 10-05-2021, 09:09 AM   #26
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
LOL JSH, do you sniff glue while reading and responding?
The guys car runs rough, he doesnt have a cam.. lol....
Send me whatever your huffing.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 10-05-2021, 10:22 AM   #27
JSH
JSH's Avatar
Drives: '20 ZLE
It called sarcasm, particularly if one reads my sig. Pot is legal in CO, so...
2020 ZL1LE A10.
Old 10-06-2021, 07:38 AM   #28
FoundNemo
Drives: 2019 ZL1
Huffing pot is an interesting term lol. Is it canned green?
FoundNemo is offline   Reply With Quote
