Old 05-10-2017, 10:24 AM   #15
DenverTaco07
DenverTaco07's Avatar
Originally Posted by Cdflyer View Post
Not bad! The extra 40lb/ft makes a huge difference! And with less boost. Not bad at all!
Extra 40?
Old 05-10-2017, 10:36 AM   #16
DenverTaco07
Originally Posted by MR 45TH View Post
Looking at that blue line you can see why I wanted a dyno tune ASAP
and with a CF of .98
542 = 553 HP
528 = 538 TQ
Why wouldn't tuner use CF = 1 at sea level? Just curious or is that with calculating DA and all that jazz? Sorry i'm a dyno noob!
Old 05-10-2017, 10:39 AM   #17
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Originally Posted by JeromeS13 View Post
What was the baseline?
Unfortunately I didn't do one.
542 = 553 HP
528 = 538 TQ
Not sure. Gonna require someone smarter than me
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 05-10-2017, 10:45 AM   #18
DenverTaco07
It's all good, I'm a dyno noob so I was just curious. Glad to hear the car is really fun to drive though.
Old 05-10-2017, 11:17 AM   #19
attymf
attymf's Avatar
Drives: 2017 SS
Yes, nothing more.
I'm installing the P1X next week and we are gonna run 7 psi with a custom Dyno tune. I'm hoping for between 560-580 rwhp
SS, A8, Procharger, M&T's and stuff...
attymf is offline   Reply With Quote
Old 05-10-2017, 11:20 AM   #20
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
What size pulley will you be running?
Old 05-10-2017, 02:51 PM   #21
attymf
attymf's Avatar
Drives: 2017 SS
LOL I dont even know.
Old 05-10-2017, 02:52 PM   #22
attymf
attymf's Avatar
Drives: 2017 SS
What is everyone with FI doing about gauges?
Old 05-10-2017, 03:09 PM   #23
DenverTaco07
Aeroforce interceptor seems to be a decent choice - if you want to read boost you need to add the 2Mbar sensor, and then they have a sensor kit for Air / fuel if you want to read that.
Old 05-10-2017, 04:09 PM   #24
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Lol might want to contact ProCharger and talk to them.
I'm very happy with my Aeroforce!
Old 05-10-2017, 05:00 PM   #25
ProCharger
Drives: Many C7's
Yeah I'm not a huge fan of canned tunes, granted they are adequate to get you by,
Actually just had a major player in the tuning world for DECADES.
Just load one of our stock files, log with his very calibrated equipment.
And said... "I not touching this file, this is spot on for a DI car, well done"
Nice pat on the back today.
At least they used SAE which is correct.
Normally you see them in STD which would have resulted in higher #'s.
Why?
That looks like a typical reading for a wideband shoved in the tail pipe.
That is the 100% incorrect way of reading air fuel on a DI car.
You will get a leaner than normal reading.
And these cars hate being rich. (for reasons I have listed before)
The LT1 is NOT and LS1, LS3, LS3, L99, LQ9.
You are very close to what it should be running AFR at WOT...
And that tiny percent I can almost guaranty is two things.
1) the wide band is in the tailpipe
2) sensor error.
Also looks like the belt needs to be tightened.
You boost curve has a wave in it, so either the following happened.
1) Belt slip
2) Traction control wasn't fully disabled, and the throttle closed for a moment
Since I see power also dipped there, it matches my theories above.
I would advise on looking into both of those.
NOTE: We use lab grade air fuel, and 5 gas analyzers here. Calibrated DAILY. We don't mess with air-fuel errors. We don't have the luxury since we have to do LV3 emissions testing.
NOTE 2: If you send me a datalog that actually has the wideband readin from BEFORE the cats, I would gladly adjust your tune if needed. Though you would be the first one out of a cubic boat load. Just an email away my friend. tuning@procharger.com
ProCharger is offline   Reply With Quote
Old 05-10-2017, 05:08 PM   #26
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Why?
Your is within 5% of what it should be running at...
2) sensor error.
This was in no way a knock on your tunes! Like I said I'm very happy with everything you guys have done. I'm just personally a bigger fan of dyno tunes and the can tune is just to get the car to the tuner.
He doesn't use the tailpipe o2. His went in place of my o2 sensors.
At the end of the day I couldn't be happier!
Old 05-10-2017, 05:14 PM   #27
ProCharger
Drives: Many C7's
Thanks sir....
I am just a little cranky after being around DI engines and tuning for about 6+ years. Just to hear "its to lean" almost on a weekly basis on something dealing with a DI motor and forced induction....(from people that have only dealt with port injected motors previously)
IF I had a dollar..... Id buy myself a nice steak dinner in Indy
But really, find that boost loss thing you got...
And I look forward to seeing your results with a file dialed into your fuel.
On that note, have a wonderful evening
Old 05-10-2017, 05:44 PM   #28
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Are you saying I should be making more boost than that?
