Old 05-06-2017, 11:25 PM   #15
ChicagoTommy
Drives: 2017 Camaro; 2017 Acadia Denali
Originally Posted by cooper1965 View Post
Wow, Im blind.. Completely missed the first line in the sig..
But, .. Those numbers are impressive.!!
M y 02 Z28 LS1 A4 on the Dyno made 307 hp and 316 tq.... (info: 37k miles, k&n intake, maganaflow catback, 342gears, 77degrees)
Car weighed 3493...
My 99 LS1 swapped Camaro put down 323ish if memory serves. I'll have to look for the dyno sheet. I had a stock 155k mile long block, Fast Toys 98mm lid, Chrs 1313 ram air, LS6 intake, ported/polished T/B, OBX catted headers, 3.42 gears, and a Yank SS4000 torque converter. Weighed 2850 without me, and went 11.68@113 N/A stock internal. Bolted on some well used LS6 heads and way old Thunder Racing 224/224 cam and made 353ish on a Mustang dyno. Weighed 2750 then and went 11.19@119. Sprayed a teeny tiny dry hit of nitrous through a Nitrous Outlet Halo dry bar, with about 4lbs left in a 10lb bottle @600psi (wasn't planning on spraying the car that night, didn't even hit it til after the '60) and went 10.62@128. I miss that 'ole turd.
ChicagoTommy is offline   Reply With Quote
Old 05-06-2017, 11:41 PM   #16
ChicagoTommy
I found the stock internal dyno pic! Wow, I didn't think I'd find this! It's a blast from the past. So 300hp/306tq pre-tune, 323hp/340tq post tune, 423/397 post tune with a NOS 78mm plate kit (full 10lb bottle, 1050psi). I hated that plate kit. It was jetted for 150hp and only made 100hp/57tq!!!
You can hear the engine cut out as soon as I hit the nitrous. Such a crappy nitrous kit.
https://youtu.be/VvruvQPCsm8
Old 05-07-2017, 04:51 PM   #17
Adp2017
Adp2017's Avatar
Drives: 2017 RS Turbo
Originally Posted by ChicagoTommy View Post
I don't think an oil cooler would really make a difference as far as cooling down the intake charge. It would be beneficial if you ran track days and were pounding on the car for 20 minutes straight.
HD Cooling wouldn't change the amount of heatsoak in the stock intercooler. It would make the engine run cooler. You would still need an aftermarket intercooler.
I will be starting to track the car soon, open days and test n tune nights. Maybe two or three times a month if I'm lucky. When it starts warming up outside I'll be seeing big power drops without some cooling upgrades.
Has anyone added aftermarket intercoolers successfully yet, or did I miss it? As far as I know Mishimoto doesn't a have their aftermarket intercooler out yet, just the piping so far.
Do you guys think it would be worth the wait for Mishimotos' bolt in one to come out or just go custom? Or is there a product out there I haven't come across yet?
2017 1LT | RS | 2.0T | M6
331 rwhp , 350 rwtq
ZZP Intercooler | ZZP Catted DP | Magnaflow Catback | Injen CAI | Tuned (BBR) | CNC Honed Turbo (TPC) w 14lb actuator
Adp2017 is offline   Reply With Quote
Old 05-07-2017, 04:54 PM   #18
Adp2017
Adp2017's Avatar
I may have missed it, but is your car a manual? If auto, what gear did you pull in?
Yes it's a stick, pulled in 4th on the first run, 5th on second ( that's where I found the most tq, but less hp), then 3 more in 4th. Every pull less and less powerful with the heatsoak.
331 rwhp , 350 rwtq
Old 05-07-2017, 04:57 PM   #19
Adp2017
Adp2017's Avatar
That's sick! Any pictures of it?
Cool how these little turbos can make LS1 power so easily now. Now if there was only a way to makes our engines sounds like an LS1..
331 rwhp , 350 rwtq
Old 05-07-2017, 05:36 PM   #20
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
ZZP has intercooler now available.
Old 05-07-2017, 06:25 PM   #21
Adp2017
Adp2017's Avatar
https://zzperformance.com/ats/ats-in...l-drive-1.html
Wonder if the piping is worth it though. Anyone tried this out yet?
331 rwhp , 350 rwtq
Old 05-08-2017, 11:53 AM   #22
ChicagoTommy
We are running the ZZP intercooler on the '13 ATS4 w/ turbobay turbo. Haven't had any issues with the intercooler, it does what it is supposed to do.
Old 05-08-2017, 12:01 PM   #23
Jason@JacFab
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
The car that's being referred to as "their shop car" has it. Dude ran an 11.97. It must work
Old 05-08-2017, 12:08 PM   #24
ChicagoTommy
Here's what my 99 ended up looking like. I've posted a link to a video in this thread, and then from there you can find more videos of that car at the track!
It started off looking like this....
This was the donor car, wrecked 99 Trans Am. The guy said he was driving it in the rain with the cruise control on, hit some standing water at 70mph and spun it around a few times while playing pinball with the retaining walls! Oh, and my SOM WS6 parked across the street!
I really would like to buy a couple other cars I owned back, or another copy of them.
My 2000 NHRA Formula Firebird - this is the car we ran on PINKS!
My 2002 SOM WS6 - was just a totally bad ass color, and was built as well.
Old 05-08-2017, 02:43 PM   #25
Adp2017
Adp2017's Avatar
beauty! glad to hear!
if it is keeping temps down with a bigger turbo (assuming you have the bigger turbo on) then that speaks volumes
331 rwhp , 350 rwtq
Old 05-08-2017, 04:45 PM   #26
rickwelch69
rickwelch69's Avatar
Drives: 2016 1LT RS Turbo 4
how is the tubo from them? I have spoke with them on the phone, was thinking of buying from them (seems like a good price, I want to keep my core)
2016 2.0 RS::K&N drop-in filter::RPM Catless down pipe::RPM Tune::Mishimoto Hot&Cold side charge pipes::65ish mm throttle body::289rwhp/328lbft
rickwelch69 is offline   Reply With Quote
Old 05-08-2017, 05:33 PM   #27
RedonBlackRS
Drives: 1LT RS 2.0T 8A HD
I need to work on clarifying my thought process sometimes... if your coolant is running 20-30 degrees cooler than usual (and the coolant is running through an auxiliary radiator), there's less heat overall in the radiator stack to soak into the intercooler. This probably doesn't make a huge difference, but might preserve a few precious ponies. A larger, aftermarket intercooler is of course the best option, but I figured I should explain why I was thinking the HD package would help.
RedonBlackRS is offline   Reply With Quote
Old 05-08-2017, 05:37 PM   #28
ChicagoTommy
No issues so far. Took them a minute to ship it out, but everything is fine after that. I believe they build them as they're ordered. I don't think they keep stock on hand.
