#15 | |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
You're talking about a completely different car with a completely different tune with completely different airflow characteristics. This is a Camaro forum and the question is about a ZL1. It's perfectly cool that you have some Z06 experience to share, but acting like my experience is irrelevant because I had a stock replacement air filter is silly when your experience isn't even with the right car. |
#16 | ||||
![]() Drives: Camaro Join Date: Mar 2017
Yes, the same exact LT4 in both. Quote:
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
#17 |
NicD,
Sorry if I've upset you. This forum is supposed to be fun for everybody. Let's both try a little harder to keep it that way. ![]() I'm sure you're a great guy and it's always easier to have these discussions in person than it is over a forum. The funny thing is, I think we agree and we're simply getting hung up on semantics. I believe I totally understand your point that without the air filter change my results would have been different. In other words the air filter makes a difference on what's achievable with a tune, and I absolutely agree with this point. My point is, given that the air filter does make a difference and the Z06 uses a different air filter (and air box, exhaust, water pump, OS, etc.), the tune-only gains on a Z06 likely will not match the ZL1 tune-only gains. You're also saying the engines are effectively the same, so therefore the expected gains from a tune-only should be about equal. However, given the previous point, either the air filter, exhaust, etc. make a difference on what's achievable with a tune or they don't. I don't see how one result can be invalid because of an air filter swap, but a result with a different car and air filter, exhaust, etc., provides an accurate expectation of gains. In a roundabout way though, we've both basically made the same point that outside influences, like air filters, make a difference on what's achievable. Nothing groundbreaking there. ![]() Your experience leads you in one direction because you've commonly seen lower gain numbers. My experience leads me in the other direction because with only a stock replacement air filter and a tune I've seen numbers far exceeding the 35 rwhp mark. It doesn't seem that either of us know the exact tune-only gains that are achievable on a ZL1. We were both just trying to help out the OP, and it probably just boils down to a subjective opinion on what we each feel is a safe tune. No big deal. Let's move on. |
#18 | |
![]() Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
Well said, thank you for not throwing us in with the rest of the pack! ![]() Michael |
#19 | |||||
![]() Well I actually do know exactly what the gains are with just a TUNE ONLY on the LT4. I do this every day and have been doing it since they came out in 2015. They have been tested AD FINEM. It isn't some special motor or special car that has special properties vs any other one. If you can't add timing to make more power than the only thing left is fueling and getting rid of the overly rich condition at WOT and that is NOT 35 rwhp.
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
No two engines/vehicle platforms will respond the same. Case in point, the l86 in the trucks (6.2) is the same engine as the LT1 other than the intake manifold, so instead of 455/460hp we have 420hp. Where the Camaro SS only sees around 10rwhp with the RF CAI the trucks are seeing over 20rwhp gains with a similar CAI kit due to how restrictive the OEM airbox is.
With that, the OEM calibration on the timing side is almost at max performance, there is not much to be gained from tweaking it any. GM has really done their job over the years on getting the timing maps perfected. All manufactures run rich, as said it is done for safety as they have to buld a car that will drive on -20° to 120° and from below sea level to 6000' above sea level on anything from 87 octane to 93 octane. If GM knew all owners would do right in their vehicles, the tunes would leave less on the table but they know there are too many owners who don't take care of the vehicles so they have to build a vehicle for the masses. |
#21 | |
#22 |
![]() Drives: 2015 Charger SRT Hellcat(732rwhp) Join Date: Mar 2017
Gents! First let me say, THANK YOU ALL FOR YOUR INFORMATION AND DESIRE TO HELP!!! I truly appreciate it all and never wanted to start any kind of a conflict.
Here is a question though-If the LT4 in the ZL1 and the Z06 is identical with identical tuning and such, why is it consistently that Z06s seem to Dyno about 20rwhp more than average Manual ZL1s? Is it an airbox/exhaust question? Or is there something in the engine ECU that is accounting for this?
Rides-
2015 Hellcat Charger-732rwhp/708rwtq 2017 ZL1 6M- Rotofab CAI, Katech ported Tbody |
#23 | |
I have not seen that correlation as I've only seen them dyno right around the same. Now of course this is me using the same dyno under the same conditions and not looking at dyno numbers on the internet which will vary wildly.
#24 |
Relates to the Z06 versus ZL1, though they are the same engine the airbox system is vastly different which impacts performance. Also I can promise you, the ECM calibration and TCM calibration will be different in many areas even with it being the same engine/transmission/computer between the two cars (other than the Z06 having 1 more gear on the manual).
#25 | |
#26 | |
#27 | |
![]() Drives: Red hot 2017 ZL1 Join Date: May 2017
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Gonna take it to the track? Drag strip?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
