Old 04-24-2017, 11:42 AM   #15
davef
Drives: 2017 SS 1LE Garnet Red
I can vouch for the T3 line from DBA. I had them on my Mazdaspeed and they were great. No issues whatsoever. Plus they look cool.
davef is offline   Reply With Quote
Old 04-24-2017, 01:26 PM   #16
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by TrackReady1LE View Post
Very good news indeed, and a great answer to a thread i posted a couple weeks ago, I will have to put a link of this thread into mine. Looking forward to hearing how they do
cool,
That's good to hear, others seem to have similar experience . I'll see if they make any difference Even if they last about the same with the OEM, I'll be still happy as I am shaving some rotational mass and the cost is about the same
glamcem is offline   Reply With Quote
Old 04-25-2017, 10:39 AM   #17
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
This is great! Thanks for figuring this out!
In the third picture, what type and size socket bit is needed for the bolts that hold the rotor ring to the hat?
2017 SS 1LE (sold)
Nightfall Gray
Th3Beast is offline   Reply With Quote
Old 04-25-2017, 12:49 PM   #18
AZ_1LE
Drives: 2019 ZL1 1LE
Tirerack has them, $355 a piece -
https://www.tirerack.com/brakes/resu...oModClar=Coupe
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-25-2017, 01:29 PM   #19
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Originally Posted by AZ_1LE View Post
Nice find.
Something I found interesting is that on the rotor rings that were posted earlier, one of the lines in the desciption says, "Exclusive to the C7 Z06 rotors, these rotors will utilize a curve vane cooling design rather than the Kangaroo Paw."
In the description on the Tirerack page for the full 2-piece rotor (disc and hat) it says that one has the Kangaroo Paw vane design.
2017 SS 1LE (sold)
Nightfall Gray
Old 04-25-2017, 08:08 PM   #20
glamcem
glamcem's Avatar
Sorry I forgot to mention that, it should be 8mm female torx but I didn't have it in hand so I've used this. The other side is 8mm standard socket. When you torque the rings, try using the female torx instead of the standard socket to eliminate slip.
This is what I used instead :
Old 04-25-2017, 08:09 PM   #21
glamcem
glamcem's Avatar
I've updated the OP (the link was not working)
I got them cheaper from KNS Brakes FYI with free ground shipping also:
https://www.knsbrakes.com/c/car-seri...2FCorvette+Hat
Old 04-26-2017, 10:42 AM   #22
AZ_1LE
Even better than tirerack, nice!
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 04-26-2017, 06:09 PM   #23
glamcem
glamcem's Avatar
Old 04-26-2017, 06:32 PM   #24
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
The ones in that are in the Tirerack link come with the hat as well. So it's a direct full replacement.
2017 SS 1LE (sold)
Nightfall Gray
Old 04-26-2017, 06:45 PM   #25
glamcem
glamcem's Avatar
yes but Corvette and Camaro has different hub patterns and so come different hats. It is not direct replacement for Camaros
Old 04-26-2017, 07:05 PM   #26
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Got it... I'm with ya now!
2017 SS 1LE (sold)
Nightfall Gray
Old 04-27-2017, 01:40 AM   #27
glamcem
glamcem's Avatar
Old 04-27-2017, 11:37 AM   #28
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
so you can reuse the hats from 1LE/ZL1? or buy new?
Evolvedx27 is offline   Reply With Quote
