Old 04-23-2017, 09:51 AM   #15
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Originally Posted by VAZL1 View Post
Something to consider! Where is everyone buying E85? I usually get my gas from Costco because it's Top Tier fuel but they don't carry E85 at least not where I live.
http://www.vacleancities.org/station...ation-locator/
Looks like Dale City, Manassas, Potomac Mills, Quantico near 22193.
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 04-23-2017, 09:57 AM   #16
KyleL
Drives: Slow
I planned on doing an intake first, followed by a cat delete, ported to/snout, then pullies/tune. I'm in the same boat as you with deciding on headers and from what I've seen, the power gains don't justify the cost and time to install. A cpr 2.31 upper and iw 9% reduction lower will spin the blower to 25k rpms at 6500, which is already 3k higher than recommended, but what a lot of c7z owners get away with. An 18% reduction puts blower rpm closer to 30k which means you'll be rebuilding it soon. All of this will run between $3-4K and put down somewhere in the 650-700 rwhp range and will drive like stock and be close to maxing out stock fueling without having to worry about running out of fuel.
Another one of my options is to do the intake, cat delete, ported tb/snout and nitrous. Cost would roughly be the same, power would be roughly the same and I'd drop iat's instead of just creating more hot, pressurized air. Downside to this is having to refill a bottle. I can get medical grade nitrous from a shop about 20-25 min away from me and it's reasonably priced, but it's a extra trip which consumes extra time and money. But I can also control when and where I use it too.
I have no intentions on meth injection bc I've seen people destroy their motors when the pump fails or they're careless and don't monitor their level, it seems like too much of a liability on a 70k car
Another point worth mentioning is your ultimate goals. Taking a look at the fast list, it seems as though the only blower cars outrunning a nitrous car are the ones with meth kits. Also, the fastest zl1 to date did it with nitrous. If pullies from c7z's will work on our cars, why not just go that route and try to bust 9's that way? Also, if I decide to do auto x and drag racing, all that power all the time may be too much for some tracks so you have the ability to run a bolt on setup for the twisties and a nitrous setup when you're chasing an et.
2016 Toyota 4Runner
2017 Camaro ZL1
KyleL is offline   Reply With Quote
Old 04-24-2017, 12:14 AM   #17
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
Would be interesting to see what those mods would gain. I'm with you on the catch can was waiting on that until I decided to pull the trigger on other mods and not void the warranty any sooner than I had too. Considering one without the clean side separator since the 17 model comes with one.
Do you think changing the X-pipe would be worthwhile?
The mods that were mentioned previously should net 70 to 80 rwhp gain the higher # with a manual tranny, money would not be wasted because you can continue to build on this platform...That's without any change to the exhaust system, X pipe would be of no benefit, pull the fuse to leave the cutouts open...
E85 conversion is a good option but the cost of the initial setup would be 3k -5k depending on the choice of injectors, flex fuel sensor, and fueling (BAP vs dual pumps)...I would never choose E85 as a 1st mod, 2nd stage mod at best...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 04-24-2017, 12:30 AM   #18
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Your build appears to be the opposite of what many of the members choose to go...If you go as planned you have not accounted for the additional fuel upgrade/injectors...Your pulley setup is to aggressive and will cause failure to the SC or motor, unless you cam it...Wasted money on porting the snout, without a porting of the heads...Upper pulley should be 2.5 with a lower of 8.6 which is 31% over driven and well within the safety margins...You may want to rethink your build...IJS...
Old 04-24-2017, 08:33 AM   #19
KyleL
Drives: Slow
What is the potential power limit of the stock fuel system? This setup I mentioned should put the car between 650-700, which seems to be where I'm seeing people get to on stock fuel. This is the formula I used to calculate s/c rpm...crank pulley/sc pulley=x. X * engine rpm = sc rpm. So based on that, the 9% reduction (or 8.75) lower with a 2.31 upper, when divided, yields 3.787878. Multiplying that by 6500 rpm equates to a sc rpm of 24,621. This does overspin the blower, however, from what I've seen from c7z's, that seems to be an rpm that makes decent power without boost falling out on the higher end, which would be the case if you were to really overspin it, say closer to 30k rpms on top of almost guaranteed sc failure. I don't see the lt4 not being able to take a few extra lbs of boost and hurting the motor, unless it runs out of fuel or has a shitty tune. A cam will help ensure it won't run out of fuel but won't have any bearing on over revving a supercharger since that forumla I mentioned is based on engine rpm
There gains shown of 15-20rwhp from porting the snout. Do I think that is a waste of money? That's all opinions since intakes don't pick up a whole lot more and cost the same as the port work. Headers are picking up about the same but costs 3x as much. I think the 2.5/8.6 you mentioned are stock sizes to begin with.
Then there's always the stock pulley setup with a little spray on top too
2016 Toyota 4Runner
2017 Camaro ZL1
Old 04-24-2017, 10:16 AM   #20
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Hey do you realize you're on the 6th gen Forum lol? All that info is correct for the 5ths but not for the 6ths lol.
Old 04-24-2017, 05:30 PM   #21
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Originally Posted by psalmon123 View Post
Lingenfelter basically told me headers were a waste of money on the pulley tune mod.
Wow that interesting news!
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 04-24-2017, 05:31 PM   #22
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Awesome! Thanks...
Old 04-24-2017, 05:34 PM   #23
It's all over the place in Texas. No worries for me and with flex fuel you can go both ways.
Exactly... If headers don't provide large HP gains then you're losing the boost you just added with pulleys by adding headers.
mlee is online now   Reply With Quote
Old 04-24-2017, 05:45 PM   #24
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Where are you in VA? There are e85 stations not listed on that website earlier in Hampton roads and several other areas.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 04-24-2017, 06:11 PM   #25
hawk02
Coupe Newbie
hawk02's Avatar
Yes, but isn't the theory that even though you lose boost with headers you're still gaining power because the engine is "breathing" more efficiently?
Old 04-24-2017, 06:17 PM   #26
Can'tHave2MuchHP
Drives: Fast
The boost is still there, same HP, but the PRESSURE is lower.
Old 04-24-2017, 06:29 PM   #27
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Agreed, less pressure more volume!
Old 04-24-2017, 07:25 PM   #28
utsteve98
Drives: 2018 ZL1 1LE, 2017 Ford Raptor
Considering these engines are putting out 650 I imagine GM designed the exhaust system well. With a SC not sure how much gain you will get from headers given the higher pressure of the exhaust already forcing itself out.
utsteve98 is offline   Reply With Quote
