#15 | |
![]() Drives: 2016 Camaro 2SS Black on Black Join Date: Aug 2016
I completely trust Doc and his tune. Doc has been in business since he got out of the navy as a jet mechanic. He also tuned my dads truck ten years ago. I don't do anything half cocked, and I check up on things before I do them. I've also been riding around for four to five weeks already on this and it's doing nothing but getting stronger, and sounding better. Doc also warranties his work for as long as I have the car. Thanks for your concern about my car. Last edited by RonAndersonJr; 04-18-2017 at 02:49 AM. Reason: Too early in the morning. |
#16 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
70 rwtq gain is impossible for just headers and exhaust. Definitely some kind of error on the dyno operators part. But it doesn't matter. As long as its tuned properly and runs good and you like it, who cares what the dyno says.
#17 |
![]() Drives: 2016 Camaro 2SS Summit White Join Date: May 2016
#18 |
![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Is this a troll post? Doc tuned your dads truck 10 years ago and that makes him a super tooner for one of the most complicated ECMS on the streets? Not saying its not possible but your graphs are straight up impossible, way too high and they make no sense. But if it drives fine and its safe I guess thats cool.
#19 | |
Apparently Doc is a super tuner if he can get a 70 lbs/ft and no one else can. |
#20 |
What gearing change did you make?
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
#21 |
![]() ![]() ![]() ![]() ![]() Drives: 18 Silverado 1500 Join Date: Dec 2015
Wow!!! E85 flex tune? Or 93 Octane?
#22 |
#23 |
#24 |
Well I'm assuming that means he went to a higher numerical ratio. It's a big fail not to re-baseline a car after a gearing or tire change (if not same diameter). You could have picked up more power if you had since higher gears result in lower numbers. Also I noticed the before and after dynos are months apart. Even if on the same dyno, that introduces a lot of variables. The biggest problem is the your peak HP is way lower in the RPM. Either someone did not set the inputs right on the dyno, or there is something funky with the tune. I'm inclined to believe it's an input issue.
I take it you're an M6? Unless you are running slicks or DRs you are going to have a much harder time launching with all that power down low if that's what your tuner was going for.
#25 |
Snackbar Tuning
#26 | |
No I'm an A8. And yes launching is a problem, I had to get used to the wheels spinning more with the increased torque |
#27 |
#28 |
