Old 04-08-2017, 11:32 PM   #15
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
Originally Posted by Gonasurvive View Post
It happened on this guy 2016 SS as well, I will pull it again and see if it happens again.
.... No comment
Evolvedx27 is offline   Reply With Quote
Old 04-09-2017, 06:56 PM   #16
JimW
JimW's Avatar
Drives: 2011 Camaro
Is that an aftermarket blind spot system ? Or dealer installed .. on the zl1 it's in the side mirrors
2017 Garnet red ZL1 A10 Procharged LME 427 L8T
JimW is offline   Reply With Quote
Old 04-09-2017, 07:05 PM   #17
catdog
Drives: 2017 Camaro ZL1 M6 pdr roof CF blk
Originally Posted by Jinkz View Post
I don't believe there is a need to pull the fuse. If you go into your settings on your radio and go to driver setttings you can click on engine management and exhaust and click on track. It will leave it wide open full time. Until you go back and change it.
btw, in my 2017 2SS, sport setting was louder than track....
try it ...
catdog is offline   Reply With Quote
Old 04-09-2017, 07:35 PM   #18
Ipockalypse
Ipockalypse's Avatar
Drives: 2017 ZL1 M6
That's how my '17 ZL1 is as well (in the mirrors)...wasn't sure if maybe I didn't get something lol
Ipockalypse is offline   Reply With Quote
Old 04-09-2017, 07:54 PM   #19
Gonasurvive
Gonasurvive's Avatar
Drives: 17 ZL1 MBM M6
Not sure if they are aftermarket or dealer installed. I just seemed to have the same problem he did. I pulled the f51 fuse correctly and the blind side markers didn't come on when I start the car, they didn't come on after driving around. Put the fuse back in and they worked again. I might try it again, but I really didn't notice a big difference. Maybe the valves were closed, so I would think when I pulled the fuse, they stayed closed..I could be wrong on that though.
Gonasurvive is offline   Reply With Quote
Old 04-09-2017, 08:11 PM   #20
Slem
Slem's Avatar
Drives: 2016 Summit White 2SS (Auto) Loaded
Interesting mine are built into the side mirrors
Slem is offline   Reply With Quote
Old 04-10-2017, 12:03 PM   #21
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
When you pull the fuse the valves open by default (power off position). So it's easy to tell if you pulled the right fuse with the car on or in service mode. Also the Blind Spot fuse is in the trunk fuse box. So there's no explanation for why pulling a fuse from the engine bay box would kill them. But considering several members including me have found a mystery relay in the engine bay box, I'm beginning to wonder if the owner's manuals are full of mistakes.
Old 04-10-2017, 08:46 PM   #22
Gonasurvive
Good to know, thanks for the info. I going to just leave the fuse in, I couldn't really tell any difference with it in or out.
Old 04-11-2017, 12:15 AM   #23
Evolvedx27
Evolvedx27's Avatar
Drives: 2017 ZL1
It's very subtle. More crackle. Slight drone on highway.
Old 04-11-2017, 07:38 AM   #24
hadkins2
hadkins2's Avatar
Drives: 2018 Camaro ZL1 1LE Hyper Blue
I put the fuse back in the 16 SS I traded off and pulled the ZL1's before driving it off the lot. 4700ish miles and no issues so far
Howard
2018 ZL1 1LE Hyper Blue Metallic
2005 Silverado 2500HD Crew Cab
1987 Camaro IROC-Z White T-Tops
Instagram @Gen6ZL1
hadkins2 is offline   Reply With Quote
Old 04-11-2017, 10:50 AM   #25
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Forgive me as I am not a Zl1 owner and just stumbled across this thread, but what exactly does pulling the fuse do? I'm fairly certain if you leave the exhaust in "track" mode it will stay open regardless of driving conditions... I understand that the valves apparently close at freeway speeds, regardless of exhaust mode, but this car leaves quite a bit of carbon build up on the exhaust tips, and my inners are pristine, as if no air has flowed out. Maybe I just don't drive long enough at a steady freeway speed
seanblurr is offline   Reply With Quote
Old 04-11-2017, 11:12 AM   #26
Gonasurvive
Okay, thank you. Guess I was expecting more, with the valves always being open.
Old 04-11-2017, 11:24 AM   #27
SuperSound
SuperSound's Avatar
It's not only at highway speed, it's at light throttle positions as well. It makes a bigger difference on A8 cars than M6 ones. Exhaust is coming out both pipes, but the soot buildup is always worse on the bypass valves because the muffler is not hiding it. Try putting yours in Stealth and cold crank it. Watch all the crap that comes out the inner pipes then. Guys running the fuse pull need to reinstall it periodically to blow out the muffler/inner pipes. One of the reasons I got a M2W controller so I can do it with a remote.
Old 04-11-2017, 12:41 PM   #28
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
Which fuse is it? F51 or F43?
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
