Old 04-21-2017, 10:15 PM   #15
WVaSS
WVaSS's Avatar
Drives: 2016 Nightfall Grey 2SS M6
Nice work. Definitely should've come that way from Chevy.
WVaSS is offline   Reply With Quote
Old 04-25-2017, 09:38 PM   #16
AlphaCamaro7
AlphaCamaro7's Avatar
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85
Looks very nice but I would like to know the prep work before painting it. And what type of paint did you use. Any primer used and did you have to sand it?
Well............ At least you tried. lol
AlphaCamaro7 is offline   Reply With Quote
Old 04-26-2017, 02:36 PM   #17
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
Very nice! I will add that per someone else's post, you do not need to pull on the entire bumper to replace the diffuser.
pjz1082 is offline   Reply With Quote
Old 04-26-2017, 02:40 PM   #18
cooden
cooden's Avatar
Drives: '16 Camaro 2SS & '15 Durango R/T
Very nice work! It's cool to see a Chevy in an Italian garage getting worked on!
'16 2SS: Summit White/Adrenaline Red/A8/Whipple Supercharger/ARH Longtube Headers/Corsa Xtreme Exhaust/Roto-Fab Cold Air Intake/Eibach Pro Kit/M228 Wheels/Lots of GM Accessories
cooden is offline   Reply With Quote
Old 04-26-2017, 02:46 PM   #19
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
If you want a shorter process with good matte looks esp for non NPP cars, alcohol and plastidip works fine on a lower body part:
Part can stay on the car, use black socks to cover pipes:
Old 04-26-2017, 02:49 PM   #20
AlphaCamaro7
I was thinking about doing this but I really wanted that gloss look. I'm wondering what type of paint I would have to use and process I would go through to achieve it
Old 04-26-2017, 05:50 PM   #21
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Hi AlphaCamaro7!,
sorry for late reply.. I had just missed your messages!
It has been done by a professional. Yes, the diffuser had to be prepared and sanded, before using a primer. You'll surely notice that the external surface is a little bit rough, so after sanding the guys at the bodyshop had to put two layers of primer paint in order to have a smooth surface to paint.
Paint is the same of the rest of my Camaro's body: the OEM Mosaic Black metallic color. As you can see, the final result is very clean and shiny, as if the bumper was just made of one part only.
If you want a professional result, it is mandatory. The diffuser has some metal clips (two or three, as I remember) that are positioned just in the center of the part. If you don't pull the whole bumper, the risk of damages is quite high. Indeed, the final finish of the paint on the recesses and corners where the two parts join can't be perfectly painted if the diffuser is not taken apart from the main bumper.
It's my pleasure! I love my car, so I'm trying to get what I want from it, without being too excessive: it's a real eye-catcher, so there's no need to push it too much.
See you!!,
Eos
Eos is offline   Reply With Quote
Old 07-26-2017, 10:51 AM   #22
Expoh
Expoh's Avatar
Drives: 2017 Camaro 1SS
About how much did they charge you??
Expoh is offline   Reply With Quote
Old 07-27-2017, 03:48 PM   #23
Eos
Eos's Avatar
Hi Expoh!,
I paid about EUR 350 for this professional job, all included. I live in Milan, Italy.
See you!!,
Eos
Old 10-04-2017, 03:48 PM   #24
Eos
Eos's Avatar
A little update: I've added the dark General Motors rear lights and the black rear bowtie by Empire.
This is the almost finished version of my Camaro's back:
See you!!,
Eos
Old 10-04-2017, 06:52 PM   #25
Expoh
Expoh's Avatar
Wow looks 100x better! I also had the dual tips but changed it to quad tips because I didn't like the plastic GM gives you I need me the 3rd brake light!
Old 10-04-2017, 06:55 PM   #26
Camaro2ss808
2017 2ss 6MT
Camaro2ss808's Avatar
Drives: 2017 Camaro 2ss
See you!!,
Eos
Nice car! Is that OEM reverse light below your license plate?
Camaro2ss808 is offline   Reply With Quote
Old 10-05-2017, 06:49 AM   #27
Eos
Eos's Avatar
Thanks for the compliments! Yes, that is the standard reverse + fog light (all are LEDs) for the European specs cars. I've painted it, too.. as it was coming from GM as raw plastic, too.
See you!!,
Eos
Old 10-05-2017, 03:53 PM   #28
Camaro2ss808
2017 2ss 6MT
If I’m not mistaken euro spec Camaro’s have turn signal blinkers on their side mirrors too.
diffuser, modification, mosaic black, paint
