Old 04-05-2017, 11:44 AM   #15
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
I'll say this whole heartedly.
You learn to effing Love the sound. (Mind you I have helical gears so its a pretty smooth one)
At idle there is a weird whistle/whine, sure, but the symphony that follows WOT is nothing short of sheer beauty. As you build boost you get a supercharger-esk whine noise crescendo... But it doesn't let you forget that there is a turbine involved. You get the higher pitched turbo style boost build noise with it. then as you shift [unless you NO LIFT which don't forget my M6 friends, is a thing as well as very useful for staying in boost] there is the glorious PSHHHHH between gears, then Boom you're back in the seat as boost is instantly available. You notice the hellcat next to you has someone crying in the driver seat. Life becomes somewhat less annoying in those 11 seconds or less :P
First procharged v8, i've had a turbo v8 before, I like this more so far.
exxit is offline   Reply With Quote
Old 04-05-2017, 05:22 PM   #16
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
And I thought I was excited before
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 04-12-2017, 07:12 PM   #17
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Just got tracking info, kit will be here Friday!!
Old 04-12-2017, 07:53 PM   #18
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I'm Torn too.
Cam or Charger.
Ahh the tough 3rd world choices we make....
Old 04-12-2017, 09:01 PM   #19
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
I'm Torn too.
Cam or Charger.
I did the big cam, and head LS build. I said for this one I wanted to try FI. Will be my first
Old 04-12-2017, 11:24 PM   #20
DevBlackSS
DevBlackSS's Avatar
Drives: 2016 Camaro 2SS M6
Any idea of when your shipped out? I also did the big cam and heads and this will be my first time going FI. SO STOKED. I was told mine was shipped out Tues.
715whp/665tq
DevBlackSS is offline   Reply With Quote
Old 04-13-2017, 06:17 AM   #21
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
It shipped yesterday. So I'd have to imagine you would be seeing yours today or tomorrow hopefully. Depending on where you are. We can have our own build off Try to get a tracking number, because it will have to be signed for.
Old 04-13-2017, 11:48 AM   #22
DevBlackSS
DevBlackSS's Avatar
Man I hope so! We can definitely have a build off! I'll post numbers as soon as I get them. Just waiting on the call from my tuner
715whp/665tq
Old 04-13-2017, 08:11 PM   #23
steelheadrob
Tactical Garage
steelheadrob's Avatar
When you ordered the P-1X, did you have the option to go with the helical gearset or is there only one gearset choice with the P-1X?
steelheadrob is offline   Reply With Quote
Old 04-13-2017, 08:14 PM   #24
nick_casper
nick_casper's Avatar
Drives: 16 2SS
I'm following your install. If the Whipple falls through a P1X full kit with helical, stage 2 IC and black finish is almost identical in price to the Whipple and is probably my next choice.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 04-13-2017, 08:15 PM   #25
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
You still have the option. I went with the helical.
Old 04-13-2017, 08:20 PM   #26
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
It's in no way a hit on you guys waiting, however just for reference mine will be here within 16 days of ordering, and that's with me upgrading half way though to the 1X.
Old 04-13-2017, 09:21 PM   #27
BradfordCamaro
SABIO
Believe I priced out $5800 for full kit as above with race valve. Add the P1x upgrade....$200??
A wee bit cheaper than a whipple.....and ready to run some high HP numbers.
Old 04-13-2017, 10:21 PM   #28
Chevy71
Drives: 2016 2SS
50 to 100 hp in that article??? Weird. Sure I read 10-15hp.
It only flows 75cfm more. 50hp tops. I LOL at the 100hp dreamers.
If you string it out to the top rpm....your 6500rpm HP max # will show improvement.
Doubt if you will see anything 2000-4000
I'll have to dig the article up, but the P1X out performs the P1S across the table. More throttle response in the low side, more torque across the graph, and 50 more HP. When MR 45TH mentioned the X, I started doing research. On pro chargers website you can download the data for every SC they build. The X is 75cfm more, but also spins 5,000 more rpm, flows more air, and makes more psi at lower revolutions. The inducer and exducer are resized and upgraded which produces less strain on the system. It's actually a decent improvement. The P1X does 50hp, the D1X does 100HP.
I'm happy for you. I think you ordered after me, changed your order, and you're still getting yours before me.
I'm Torn too.
Cam or Charger.
I went with both! If you're keeping a budget and want the most bang for your buck, donthe SC first.
IMO, the centri SC is a more street friendly set up, and makes more power. I think your plan B is a solid plan if Whipple doesn't produce.
Chevy71 is offline   Reply With Quote
