Old 03-31-2017, 11:22 AM   #15
ChevyRules
Drives: 2021 Tesla Model 3 LR
It's all about weight distribution. Reason why that spot is safe for a 4 point lift is because the weight is spread out more. Where it isn't recommended it to lift the car up from that point using a floor jack since you're putting more of the cars weight on that one spot.
Lesson here: Go by what GM tells you to use when you jack the car up.
ChevyRules is offline   Reply With Quote
Old 03-31-2017, 11:24 AM   #16
vet757
vet757's Avatar
Drives: ^^^This
+1
vet757 is offline   Reply With Quote
Old 03-31-2017, 11:57 AM   #17
00 Trans Ram
00 Trans Ram's Avatar
Drives: 2017 2SS
"Go by what GM tells you"
If we did that, there would be no Camaro6 forum. None of us would put on wider tires. We wouldn't have aftermarket camshafts, turbos, or any other engine bits. We wouldn't modify our cars in any way, because "GM told us" this was what the Camaro should be.
No one would be using Dexos2 oil because "GM tells us" to use Dexos1. No one would use aftermarket brake pads, because "GM tells us" to use only GM-approved brake fluid. No one would be using LED bulbs or similar, because . . . well, you know why. No one would be running E85, because . . . should I say it again?
My point is that "GM" didn't tell you to use those jack points. While we don't know which person within the GM hierarchy wrote that specific section, we can all probably rest assured that it wasn't an engineer. A marketer perhaps, who had to write it for the "average Camaro owner"? Perhaps a lawyer, worried about liability claims when some jackass uses the aluminum section right next to the steel? We'll never know.
But, until I start seeing these cars being delivered on 18-wheelers with lockdown straps hooked into the thin sheet-metal pinch welds, I'll continue to jack from the high-strength steel frame under the car.
00 Trans Ram is offline   Reply With Quote
Old 03-31-2017, 11:59 AM   #18
00 Trans Ram
Drives: 2017 2SS
While I'm ranting . . . the first mod EVERYONE should do to their Camaro is the "manual delete" mod. Where you take the owners manual and chuck it in the garbage can.
Also, let me say that I'm not upset with anyone here. And, I'm not even arguing with the people. I'm simply arguing against myths.
As I said, multiple people in here and other threads have said and even shown on videos "don't jack from this black area - this is soft aluminum". Ummm - OK - if it's aluminum, how is my magnet sticking to it?
Old 03-31-2017, 12:06 PM   #19
CAM-FIFTY
CAM-FIFTY's Avatar
Drives: 2016 Red Hot 2SS
Not sure why you are ruining your own thread by turning it into a rant against GM.....
You have put up your point, let people make decision if they want to use it.
For me, GM made a very questionable design with pinch welds and bolt-ons provide a cheap insurance against screw ups.
2017 Black Z06 2LZ M7
2016 Red Hot 2SS A8 - Sold
My Camaro journey here and here.
CAM-FIFTY is offline   Reply With Quote
Old 03-31-2017, 12:09 PM   #20
datboi448
datboi448's Avatar
Drives: 2013 2LT RS, 2017 ZL1
i want a magnetic bowl now
datboi448 is offline   Reply With Quote
Old 03-31-2017, 12:21 PM   #21
00 Trans Ram
Drives: 2017 2SS
Who said I'm ranting against GM? The owners' manual serves a great purpose. For people with little/no car knowledge, it's a good resource. But, for people with a little auto knowledge, it's more often a hindrance.
Old 03-31-2017, 12:22 PM   #22
00 Trans Ram
Drives: 2017 2SS
They're extremely useful. Working in your engine bay and need to keep track of bolts you remove? Stick them in there. But, my favorite is when working under the car. Stick the bowl upside down next to where you're working, then stick the bolts to the bowl. That way they're right in front of you, instead of somewhere near hour shoulder, behind your head, or under your ass on the ground.
Old 03-31-2017, 12:58 PM   #23
lDejavul
lDejavul's Avatar
Drives: Camaro SS
I can tell you first hand that the points you say you can jack by, if you jack by those points and your pad is not wide enough those will fold in. I had an older low profile jack that did just that. It was a round pad but it wasn't large enough. Bought some hockey pucks and cut them and they work fine on the pinch welds. Want pics to prove it?
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB
Pray ported MSD IM
Rotofab CAI
BTR 225 CAM
PRC 312 CC Ported Heads
Katech Oil Pump
DSX Flex Fuel E-85 kit
QTP exhaust cutouts
Full JLAudio Stereo Build w/ 13-W6
lDejavul is offline   Reply With Quote
Old 03-31-2017, 01:15 PM   #24
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
What a mess. Look at where and what direction the structure is designed with regard to force vectors, and that will dictate which areas are acceptable for a jacking point.
This thread goes in the category of "if you don't know what you're doing, stop and take it to someone who does". Example of doing it wrong:
^^In the case of the Type 111 Lotus, there are 2 jacking dots and 4 jack-stand dots. Discount Tire here didn't do that.
Old 03-31-2017, 01:27 PM   #25
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 03-31-2017, 02:32 PM   #26
camaromike77
camaromike77's Avatar
Drives: S O L D
Club F1FTY
Old 03-31-2017, 03:14 PM   #27
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 03-31-2017, 03:22 PM   #28
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Originally Posted by GTIanZ28 View Post
Prime example of an idiot using a lift. Love to have heard his reasoning behind why he thought it was fine to have lift arms touching the body of the car.
