#15 |
![]() ![]() Drives: 1992 Z28 1LE; 2015 Zl1 Join Date: Mar 2009
I'm with the GT350 owners on this. Car going into limp mode in a 20 minute HPDE session is not acceptable for any sports or performance car. I expect that out of a GT or SS even if they don't have the PP/1LE package. Chevy made the same mistake with the Z06. I expect the ZL1 (without the 1LE package) to perform fine on the track without going into limp mode. I will be very disappointed if we start getting reports of ZL1s going into limp mode. Ford got the message when they made the track pack the base car for the next year. They should have done that from the beginning.
Whether it will hold up in court is another matter. In the court of my personal opinion though it's pretty clear.
1989 Camaro RS convertible- Sold
1999 Camaro SS - Stolen 2x 1991 Camaro Z28- 1991 Camaro Z28 1LE- 1992 Camaro Z28 1LE- 25th anniversary 2015 Camaro ZL1 |
#16 | |
![]() ![]() Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
It was pretty clear from the get go which one would be track worthy, and which would not.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
#17 | ||
Moderator.ca
Ford did NOT intend the base GT350 to be track capable, knowing that most people would never take it to a track. However, they knew that some would track it and therefore offered a track package with those specific buyers in mind. The people suing Ford knowingly bought the car without getting the track package and then proceeded to take it to a track anyways. That is on them. Think of it like this: on pickup trucks, there exist towing packages that can increase the tow rating of the truck by several thousand pounds. Whose fault is it when someone takes a half ton truck that isn't so equipped, hooks up a 12,000 lb trailer (instead of the 8500 lbs they should have), and cooks the transmission or causes some other failure. The manufacturer for not giving every single truck the maximum capacity, or the owner for exceeding the known capabilities of his truck? Or what about suing because your ass gets cold in the winter and your car didn't come with heated leather seats, only basic cloth ones. Sure, you could have ticked the option box and gotten the upgrade but when you ordered you had no idea that you were ever going want that capability. The manufacturer knew the car would get cold in the winter, but they knowingly sold cars without heated seats. How dare they! In my opinion, both of those scenarios make just as much sense as suing because your non-track pack GT350 was not track capable. How much more obvious does it need to be? Put it in the owners manual? Oh, right they pretty much did: Quote:
So, they outright say that the GT350 needs coolers for track days and sustained high speed driving (coolers that come with the track pack and R model). And, they warn that it will go into limp mode if it starts to overheat. Sounds like none of the folks suing bothered to spend a couple minutes reading their manual.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#18 | |
Iron fist, lead foot
Drives: 2003 Mustang Cobra Join Date: Jul 2013
I imagine that this lawsuit was more from lawyers, thinking they can make a quick easy buck, than the owners themselves.
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
It was a poor decision on Ford's part gave them their $49,900 base MSRP headline that was quote by fans and press whenever discussing the TP or R performance. That's where the water got muddy. Edit: there is a thread on Camaro6 regarding the inability to even register a reading on the transmission temp gauge of a 1LE. The SS has the same cooling and even with the A8, I need to aggressively manual shift up and down to register heat on the gauge during street use.
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 03-25-2017 at 09:08 AM. |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 F150 Join Date: May 2014
This is a clear case of Ford trying to get a great price point and skimp out with what the car needs, especially one designated as a track car.. Let's be honest, the 350 was looked at as a track car whether you get the R or not. They all should have had the cooling without having to option it out, but they obviously wouldn't have been able to hit that price point all the Ford fanboys were bragging about.
GT500 also needed a track package. Mustang GT is also gimped from the factory. Just seems to be the way Ford does things. I still don't think that this lawsuit will accomplish anything for these people. I recall when the blue oval boys talked about how the 1LE would cost as much as GT350 and not be as good.. 1LE costs 14k dollars less. That's huge. Besides the unique engine, the GT350 sounds like a ripoff. |
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
The lawsuit depends on believing marketing hype as being some sort of guarantee....
You get what you pay for usually stands true....and that includes coolers for the track.... Does everyone who eats Wheaties suddenly become just like the athlete on the box?....I think not... |
#22 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 21 Bronco Join Date: Jun 2012
#23 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
![]() I think this lawsuit will be won or lost on the reasoning behind WHY Ford is now specing the extra coolers, or the track pack, on all models of the GT350. If it's to save cost, nothing more or less, I think Ford will win. But if there is any indication that the move was to quell future customer complaints then Ford should be on the hook for upgrading all base GT350's with the coolers. I read somewhere that some fine print said the car is not track capable unless equipped with the track pack/coolers. Glad it's not happening to my car lol
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#24 |
![]() ![]() Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport Join Date: Mar 2013
IF Ford has to answer the question: Why in the 2nd model year of the GT350 did Ford make the features that were in the 2015 GT350 Track pack(trans cooler, dif cooler etc.) standard and raise the base price to 57K, then it could end well for the plaintiffs.
Because clearly the only reasonable answer was the GT350 was not 'track ready' in the base or tech package format of the 2015 GT350. If they can't get Ford to answer that question, then it will be a loss for the plaintiffs.. |
#25 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: Oct 2015
Dumb. Can't get made because you opted out of the coolers. It would be like suing when you bought the gas engine because you didn't want to pay the premium for the diesl and it couldn't tow the same as the diesel without overheating. They won't win.
#26 |
But then why did Ford make the coolers standard in year two and also add a supplemental to the owners manual covering track use after drivers of the GT350 started experiencing issues at the track.
You can't assume that everyone who buys a car knows exactly what components make it 'track ready'. In fact judging by the sales numbers, only 30% of the buyers knew what they were doing. Of the 5,643 Base, Technology Package, or Track Package Shelby GT350 Mustangs built by Ford, 3,991 (70.7%) were the Base or Technology Package models. In contrast, only 1,652 (29.3%) were equipped with the Track Package The more I think about this case, the more I am in favor of the owners.. and I don't care for Ford or Mustang drivers.. so I don't care which way this is eventually resolved. |
#27 |
![]() Drives: 2012 Ford Focus Join Date: Jan 2014
You can't assume that they combined the track pack components to remedy the overheating issue as well. It could have been done simply due to the lack of takers on a base GT350 as well as a TP GT350. As far as I know, most GT350's were ordered with the Tech package (probably more dealer oriented than buyer).
#28 |
I doubt that Ford lacked knowledge that the base model would overheat if tracked in any manner more than just stop light warriors. They do extensive testing on all vehicle before they are in production. I just think they overestimated the intelligence of their target audience when offering them the option not to get the coolers. They more than likely sold the base model simply to get it under the $ mark for the people who only wanted the look of a badass racecar and would never actually use it at a track. Again, Ford underestimated cheap/stupid people.
