#15 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
I wonder if the problem some of you may be having may be related to left over dried "thread locker/sealant" in the threads of the hole that are left over from removing the plug? Perhaps excess goop squished behind the plug during assembly. I noticed quite a bit of goop on the threads of my plug. If there is left over and it's compressing behind the mishi plastic fitting causing you guys to break them before they can seal?
When I put mine in today, I just lifted (forced) the CCv tube(s) up high enough to clear the angled part of the fitting at each turn in. The sealing washer of the fitting was flush with the valve cover, and I slowly kept turning it until it pointed to the front. Guess I'm lucky... Unless it was supposed to point toward the rear? Sent from my iPhone using Tapatalk |
#16 | ||
Drives: Mostly Stock Join Date: Jul 2012
We'd rather you not have to break these tabs and have to replace them to install the catch can. Hope this helps! Quote:
So the PCV fitting can point in either direction. We packaged the one hose section in two different pieces with the straight adapter so you can adjust it to fit. If you're having any more trouble, check out the install video I linked above. Thanks! Nick |
