#15 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I'm 99.9% sure those won't fit. The front's almost definitely will contact the strut without a spacer. I have the apex 19x10 et25 and have only a few mm of clearance between the wheel and the strut. Those will be about 3.4mm further in than mine. That will be very close. Good luck, I hope they work! And the rears are going to poke out of the fender quite a bit.
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
#17 | |
whenever you shave 7-8 lbs of rotational mass, while inducing shorter gear ratios (thanks to shorter overall height), and wrapping with an R comp tires that can basically never overheats you gain a lot ..I mean A LOT.. that's a difference you can feel at every corner if you use your brakes and tires hard .. it may or may not worth the hassle for many and I get that, but it makes a lot of sense for those who want to plan to attend many track events in one season. OEM tires are not just that good, they can't be ..they're street tires. Keep in mind, OEM pads are prone to fade also, Randy Pobst mentioned that during the Laguna Seca Lap by Motortrend magazine. I didn't mention that I am getting Raybestos ST43 pads so R comps necessitate more aggressive tires, that can take a lot of heat easily because of the heat generated by aggressive pads. Mismatched pad/tire is a big issue, "ice mode" was not fun with my '13 C6 GS, won't make the same mistake.. I assume they will overheat easily just like RE71Rs or any other tires in that category, it simply ruins the whole track day experience because instead of focusing on driving you battle with overheating tires especially . Yes you can still set a very competitive lap time but you really need to do that soon after the warm up lap. Then they start to fall of dramatically. not for me, I will not spend my time fixing issues that are not caused by me but stupid set of tires (or whatever) especially when I am not saving anything (or even lose in some cases because of the shortened life span of the street tires that could be used for long miles on the street or auto-x) For those who don't want to plan to attend as many events OEM might be a great alternative but as soon as you attend more events you need to start thinking about the consumables and the total cost and performance benefits of the other. Having two separate setups approach always seemed to be a better fit for my driving style. As I look at the other people who track more often I see the same thing , they simply have two sets of pads, rotors, wheel/tire combo. Each his own
#18 | |||
I am almost sure the rears will be just fine maybe stick out a bit and I can have someone custom fit a flare for me if it bothers. For the fronts, I will see if I can do it or not I think I will be the guinea pig, wish me luckQuote:
Who are they? Apex? I've seen many people used Apex wheels on both street and track on their Gen 5 , Gen 6 camaros and they all had the same bolt pattern 5X120. Am I missing anything?
#19 | |
#20 | |
![]() Drives: 2017 SS 1LE Join Date: Oct 2015
It will work, I was just told to keep on eye it. |
#21 | |
SABIO
Thanks
#22 |
#becauseracecar
I have not tried fitting the 1LE wheels but they will fit. The struts are the exact same, just a different mag ride computer calibration. I'm excited to see how these might fit up. If you have a friend with a mag ride SS, you should see if he'll let you pop off one of his fronts and test fit your wheel before putting the tire on to check clearance since you don't have yours yet. Even if it does fit, getting it to fit with a track alignment will likely be impossible. Mine are tight without doing my track alignment yet. Good luck.
#23 |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
Wow, You got the wheels and tires before you got the car? Man, you are very anxious to get out onto track, I see.
I got the same type wheels in 19*10 et25 like Eric SS, and wrapped them with RE71Rs but still 1.5 more months wait before I can really use them. ![]() Good luck on your fitment, and let us know how things go.
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd 1100: 7/27/15 <SSWNNN> 3000: 9/04/15 <TPW:10/19/15> 3800: 10/19/15 <VIN: 117740> 6000: 12/16/15 |
#24 | |
#25 | |
I am really surprised how tight the clearance is on these cars (vs the Gen 5 camaro) . There is about 12-14mm clearance on Gen 5 Camaros if I am not mistaken. I would never think moving the wheels about 8mm to the struts would be an issue, this will be a first ![]() It is harder to tell from the pictures but were you able to measure the clearance? One thing to mention I saw you went with 285/35/19 that would add additional 15mm rubber on top of the 305/30/19 tires (may or may not be an issue I don't know). According to my calculations I will be only 3mm closer to the struts compared to your setup and already ordered some 3mm aluminum spacers. I will also get a 5mm if needed but I wouldn't go anything above 5mm for track use just to be on the safe side. Speaking of the alignment, it looks like the only good option for us is to find some sort of camber plate as it will move the suspension as a whole to gain more negative camber. I will eventually go with ZL1 1LE suspension, wheel/tire combo and if necessary ZL1 front fenders. I wouldn't be happy with camber less than -2.2 camber up front. I will provide some pictures when car arrives here.
#26 | |
#27 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I use this tire/wheel compare link, It takes into account the role the tire plays because the tire is wider than the wheel, and may (sometimes) be the first component to hit something:
https://www.rimsntires.com/specspro.jsp Here is what I found with your setup from the 1LE fronts to the 10.5" APEX wheels: And the Rear: You can add a spacer up front to gain back your original tire to strut clearance, about a 12mm spacer, that would then push the fronts out an additional 12mm, see below
"KEEP THE FAITH"-Fbodfather |
#28 | |
This member is experimenting with the Z/28 front wheel (ET11): http://www.camaro6.com/forums/showpo...2&postcount=22 Not much room for additional negative camber though) Depending on how much (max) negative camber you run at the track you will need to find what kind of spacer you need to maintain a safe tire to strut gap.
