Old 03-07-2017, 06:49 AM   #15
datboi448
datboi448's Avatar
Drives: 2013 2LT RS, 2017 ZL1
Originally Posted by WEAPON-X View Post
The bricks inside the Whipple are about twice the size of the LT4, you can see how much wider it is sitting over the heads. For the front coolers, while the factory HX are OK, they're surprisingly inefficient for having three of them. The HX are the same on the V3 as the ZL1 as well. We already have the Triple HX kit for both cars since they're identical and recovery time was reduced by 400%! But that's also because we have 154% more fluid in ours
Individual cooler numbers:
Side Cooler Stock: 15oz (444ml)
Side Cooler WXM: 27.5oz (813ml)
Volume Increase: 12.5oz (369ml)
=83% Increase in cooler volume
Center Cooler Stock: 19.5oz (577ml)
Center Cooler WXM: 60oz (1,774ml)
Volume Increase: 40.5oz (1,197ml)
=207% Increase in cooler volume
Total intercooler system numbers (One side cooler plus one center cooler):
HX System Stock: 34.5oz (1,020ml)
HX System WXM: 87.5oz (2,588ml)
Volume Increase: 53oz (1,567ml)
=154% Increase in cooler volume
What is the weight difference with the larger HX and more fluid? Would be interesting to see if the weight distribution at the front changes as well.
datboi448 is offline   Reply With Quote
Old 03-07-2017, 02:02 PM   #16
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
More math than I have time to do at the moment, but it'd definitely be heavier in the front with all that extra fluid. Don't think I'd want to add the larger heat exchangers unless they were absolutely needed.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 08-15-2017, 07:56 PM   #17
soceur77
Drives: 17 NFG ZL1 17 GTR 22 RS6
bump for updates
soceur77 is offline   Reply With Quote
Old 08-15-2017, 08:17 PM   #18
soceur77
just went t wepx web site and they don't have much listed for the ZL1?
bigger, blower, supercharger, whipple, zl1
