Old 02-28-2017, 04:55 PM   #15
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Originally Posted by Fraxum View Post
Epic post!
I see your best run was with a 2.0889 (2.1) 60'. This is the key.
in my previous 5th gen Camaro life I was able to get (as I remember) a couple of 1.95s on stock Pirellis (SS) but My best on the Goodyear Supercar tires was 2.00s (1LE and ZL1). On my current SS runflats I have done a couple of 1.93s.
I know the Goodyears on your car are of a different compound (tread?) than mine were. They really are not made for launching and excessive burnouts made mine very greasy and the sidewalls are stiff.
Thanks! I try to make my posts informative and enjoyable - one that I would enjoy reading.
Anything below 2.0 would be a major jump for me, indicating I'm doing something right. Yes the F1 G3 model has new compounds, specifically designed for the ZL1, or so I've read. They're optimized for road track use. They do get "greasy" with too long a burnout, especially if the track is slick too. I was getting them to stick pretty good so long as I didn't apply too much throttle. I've just got to get the right balance of throttle pressure and clutch release. I'm sure that'll be less of a factor with slicks or DRs.
Have you tried a very light burnout just to get the water off and then a street start with the nannies off where you ease out the clutch @ 2K then feed in as much clutch as the tires will take. I bet that is harder to do in the ZL1 as the power comes on sooner/harder.
Yes, they spin too easily without the heat.
--Cal
cwebster is offline   Reply With Quote
Old 02-28-2017, 05:10 PM   #16
cwebster
Cal
Originally Posted by Cdflyer View Post
The new ZL1 has an unfair advantage over the tank a$$ Hellcat. They're heavy. My buddy has a '15 and my '16 SS will put up a fight until he gains significant traction.
As for wheels and tires, you should be able to clear 17's assuming the brakes aren't any bigger then the SS brakes. I clear a 17x10 Weld with Hoosier 28x10 slicks. Thing hooks great N/A and we'll see what happens with the ProCharger in April when the tracks open up. Get the 60' down a bit and watch the ET drop about double.
Actually, I think the Hellcat and 6th Gen ZL1 are pretty close in terms of available torque at the wheels vs total mass (inertia) that the torque must overcome. Hellcat is much heavier, for sure, but the added 50 HP & torque makes up for that. With similar trans and tires it should be a pretty close race.
I doubt 17's will clear. There's only 1 1/4" clearance between the brembo caliper and rim on the rear. My rotors are much bigger than yours: Front: 15.35" dia, 1.42" thick | Rear: 14.37" dia, 1.1 inches thick.
--Cal
Old 02-28-2017, 05:28 PM   #17
cwebster
Cal
Originally Posted by Snowblind View Post
Are you sure about your weight ?? Car and Driver lists their test ZL1 at 3933 if I recall correctly.
No, not sure. That was a rough estimate based on 3600 lbs curb weight minus 3/4 tank of gas. A more accurate estimate would be:
Approx curb weight: 3795 lbs
1 Gal gasoline = 6.183 lbs
3/4 of 19 Gal tank = 14.25
14.25 x 6.183 = 88.10775
3795 - 88 = 3707
I'll let everyone know if I do get it on a scale, though.
--Cal
Last edited by cwebster; 03-01-2017 at 03:14 AM. Reason: corrected est race weight
Old 02-28-2017, 05:39 PM   #18
cwebster
Cal
Originally Posted by 762CAT View Post
Careful now! My Hellcat is stock except the Legmaker CAI and Borla exhuast. Exhaust does nothing on these cars except change the sound note. Oh and the aluminum Drive shaft..lol. No real power mods though...Another fully stock Hellcat Charger was running the same times. Both of us on Drag Radials of course. If fact he stuck around till the end of the day when it cooled down even more and ran a 10.75...the lucky bastard!
I only know one manual Hellcat around. He lives in Raleigh and I don't think he races at all.
I wish I would have taken note of what slicks that 2017 SS was on...I checked and I don't have any pictures of him either. His 60ft times were good.
HaHa! Why be careful when you can be cool.
Of course we both know the auto would give you the edge but an M6 should be pretty close to the ZL1, when you take into account how much more inertia the extra 50 HP/tq must overcome. CAI does boost HP, especially on a supercharged motor. Only way to know how much is dyno before and after adding. Side benefit is the satisfying whine. If you say your exhaust upgrade offers no performance gain I'll take your word for it.
You need to start taking an entourage with you to the track to help get videos and other little odd jobs. I'd like to see that monster run.
--Cal
Old 02-28-2017, 06:17 PM   #19
762CAT
762CAT's Avatar
Drives: 2016 Challenger Hellcat
^^^^ ya I know right. I've got some great photos from drag racing and I think I have a couple videos buried somewhere. I have vids of the 1 mile and 2 mile..but I do need to grow my entourage. Hopefully you can see it in person. Next time I see your ZL1 i want a ride! Sat in it but want to feel it.
You will have to let me know how that autocross is this weekend. Never been.... I think I'm gonna talk to the airfield manager and start campaigning for Cherry Point to host a runway event...mile racing or beyond. How sweet would that be!
Fly a 850whp HellCat Challenger
Drive a 19000 HP C130J
Reserved parking for ZL1 1LE….whoops filled the spot with a Charger Hellcat daily…….
762CAT is offline   Reply With Quote
Old 02-28-2017, 06:22 PM   #20
762CAT
762CAT's Avatar
I wish the exhaust offered performance upgrade...trust me. They did a great job on the factory exhaust..I think Chevy did as well on the ZL1...your car sounds phenomenal BTW. I only changed the exhaust because a friend sold it to me cheap and I like the way is sounds.
Old 02-28-2017, 06:26 PM   #21
Steve 2016 SS
Drives: 2016 Camaro SS
Agreed, I have a 16 SS and best time of 11.967 with street tires (see fastest list) with my M6. The day I ran that there was a Hellcat Challenger there and he didnt want to run me after asking 5 times (oh my cars to hot, Oh these MT D/R's are crap, oh im low on gas...whatever.) I think that beast of your will run the cat down. just my option.
Steve 2016 SS is offline   Reply With Quote
Old 02-28-2017, 09:04 PM   #22
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
That's what I'm saying. My car went 12.04 on the slicks completely stock otherwise. When I took my buddy (who owns a '15 Hellcat) for a ride, he was very vocal on the fact that the SS will put up a very good fight. Add a supercharger and you jump ahead. I guess we'll just have to see what happens once my ProCharger is done going on. It'll probably make him cry.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 02-28-2017, 10:54 PM   #23
ULTRAZLS1
ULTRAZLS1's Avatar
LOL what in the world. An SS a good fight for a hellcat?
Yeah if its blowing the tires off. Other than that its not even close
Article 1. Im running lightweight drag wheels and tires, CAI and ported throttle body. Got smashed 11.7 to 10.8. Stock hellcat with DR. I even treed him slightly. absolutely blew my doors clean off.
As far as a supercharher only SS. Yes it can get the job done but you better be proper. And no one is getting blown away.
Livernois had their Maggy only a8 SS with DR at the track and it took them all night to run faster than the hellcat. They finally got down to 10.6@129. I was there.
As for the zl1. So far it has not proven itself to be faster than the hellcat at all. It should be very close. But im not convinced at all.
Im a chevy guy to the core but im calling the truth here.
Old 03-01-2017, 02:45 AM   #24
cwebster
Cal
We'll definitely have to do some ride-alongs next time. I've driven a stock 2016 Challenger Hellcat on the skid pad and autocross at Bondurant Racing School. I've also done a ride-along in one on their road coarse with a professional racer. It was a thrill keeping that beast within the cones with all that power on tap. I was blown away at how the skilled racing instructor could carve the corners with it, though. It tries to understeer coming into a turn and without careful throttle input the ass-end will loose grip easily on the exit. The Viper is tighter and much more balanced for the turns - like the ZL1.
I will get GoPro footage from the autocross event and post a thread next week. Autocross is the next best thing to road track racing. It's not wheel-to-wheel racing but it's very technical and feels faster because of the challenging turns and slaloms.
If you can help arrange something like that I'm sure they'd be plenty of participants. I'm in for sure! They only time I've seen cars on the runway was at the air shows by pros with plenty of liability insurance, though.
--Cal
Old 03-01-2017, 02:59 AM   #25
cwebster
Cal
(snip video)
(snip video)
Yeah, I think you're right on the money with that call. ZL1 M6 to Hellcat M6 with similar tires would be a good, close race. 762CAT's machine is pretty close to stock and he's doing 10.8's.
--Cal
Old 03-01-2017, 04:27 AM   #26
wnta1ss
Drives: 2017 Camaro 1SS
I think a STOCK M6 Hellcat will be a good race for Cal's STOCK M6 ZL1. I have talked to a drag racer who has an M6 Cat and he told me his best time was 12.0sec.
A bolt-on A8 Cat with Drag Radials is a different story. I've seen one run as quick as 10.7@127 on a cold day.
Old 03-01-2017, 06:59 AM   #27
762CAT
762CAT's Avatar
Sorry Cal...seems every time I post on one of your threads it turns into a Camaro vs Hellcat thread...lol. Everybody seems to know that one Hellcat owner who can't drive worth a lick. He must get around.
Back on topic! Can't wait to hear about the autocross. And can't wait to see that car with big ol' meats on the rear. FYI Fayetteville is doing a test and tune this Friday night at 7pm in addition to the usual sunday. Prob a bit much with your autocross plans but thought I'd let you know. Weather is a high of 62. Track prep there is great but may be slicker at night...don't know. Never been at night.
Old 03-02-2017, 10:14 AM   #28
cwebster
Cal
HaHa! Yeah... Like when I go to the drag strip I have a target painted on my back. A Hellcat owner on a Camaro forum has to expect to get painted with laser designators.
I'll be posting a thread at least by Monday with videos. I may post something early - Sat eve if I'm not totally wiped out. I'll be there from 7:30 AM to 5:00 PM Sat and Sun. Half the participants race in the AM session and the rest in PM. When not racing, you do track work (calling in cone hits, reset cones, etc.). Track work is exhausting for me with all my old-man aches and pains so if I draw the afternoon shift I'll be in bed early.
Thanks for the notice on the FMP schedule. I saw that on the web site but I thought it might be a mis-print. If I can get the car where I want it today, I may make the trip. I'll text or call you...
Changing trans fluid today. One of the few minor gripes I have with the new ZL1 is the sometimes clunky shifts. I can feel the synchros meet and mesh. It's not bad but, compared to the 4-speed Muncie in my previous '70 Nova SS, it's annoying. I'm changing transmission fluid today, from the GM 88861800 / ACDelco 10-4033 (non-synthetic) to Royal Purple Sunchromax. I've read good reviews on this on many car forums and elsewhere. Royal Purple even provides a cross-reference from OEM PN to their recommended comparable product. I've already changed the diff gear oil twice, per the Performance Supplement recommendations. It says nothing about the transmission fluid but I figure those gears and bearings are taking at least the same load as the differential so I'm changing the fluid and replacing it with something known to extend the life and smooth out the shifts.
In other news, I've also discovered a reliable vendor that provides 5W-40 motor oil that meets the dexos 2 spec. cited in the Performance Supplement. Amsoil "European Car Formula 5W-40 Improved ESP Synthetic Motor Oil" meets the spec. I bought a case of 4 gallons for $119 [AFL1G-CA ]. There is still no US vendor or web site that sells the 0W-40 dexos 2 oil - the preferred viscosity for racing, though. I'm going to file a complaint with GM/Chevrolet. Their service departments don't even have dexos 2 oil. My last (free) oil change was done with dexos (1) oil. There's a lot more to this story - enough for a separate post.
--Cal
