Old 02-26-2017, 08:54 PM   #15
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
Originally Posted by WhyUMad1LE View Post
Did you check the oil level after the dealer serviced it? I've read on here that some technicians mistakenly go by 5th gen specs.
Was going to post this something. I bet oil wasn't at proper level. I also hope you put in the dexos2. Sorry man.
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 02-26-2017, 09:11 PM   #16
MTS2020
MTS2020's Avatar
Drives: 2017 HBM SS 1LE
Well, he took it to the dealer for the service that was done for i, so if proper oil type wasnt put in it, the dealer needs to hold some responsibility for the kaboom also....
Sucks man, hope all turns out well for you. Keep us posted
MTS2020 is offline   Reply With Quote
Old 02-26-2017, 09:41 PM   #17
thescreensavers
thescreensavers's Avatar
Drives: SW 1SS 1LE / Jeep XJ
Originally Posted by Ls6larry View Post
What was your oil temp, also did you switch to the 5-40 oil, I have been preaching oil cooler and all the "experts" on here say " this car is track ready" even though it's a proven point oil over 250 looses its ability to lubricate the hotter it gets but the "experts" think 270 is just fine. I'll be following this post to see if it's covered and i gm sees if it was a high oil temp issue and won't cover it
Oil doesn't lose its availability to lubricate at elevated temperatures, it just gets thinner.
250F isn't terrible for quality synthetics. Adding an thermostatic oil cooler while beneficial you may have warranty issues associated with it.
Op should be OK since his car wasn't modded obviously an engine defect caused the failure guess we will hear once he gets it back.
thescreensavers is offline   Reply With Quote
Old 02-26-2017, 10:29 PM   #18
Vintage
Drives: 2017 SS 1LE
Guys, all good questions. I will stress, dealer serviced 100% with their knowledge I was taking it directly to track this weekend and spoke at length with Service Advisor about same as they service Corvettes and Camaros that are tracked - it was a $1,000 service when you include the strut bar I had installed. I do this specifically because I do not want blow back if anything ever happens. The same reason I do not mod my cars. The car was serviced Tuesday. I will pull the service ticket tomorrow and relay details if they can be derived from the ticket as to oil amount, type, etc.
Vintage is offline   Reply With Quote
Old 02-26-2017, 10:44 PM   #19
Yellow6thGen
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible
Yellow6thGen is offline   Reply With Quote
Old 02-26-2017, 11:17 PM   #20
meyouand987.2
Drives: 2011 Cayman R 2017 1LE
Man this sucks, I hope the dealer steps up! So on my 2015, TWICE the dealer only put in 5 qts....TWICE! Always check it before you roll out of there.
meyouand987.2 is offline   Reply With Quote
Old 02-26-2017, 11:24 PM   #21
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
You did the right thing by doing all of the track day services before tracking it for situations just like this. I have done the same thing (correct Dexos 2, rear end flush, A8 service) and I recommend everyone do it that plan on tracking their car. Don't give GM a reason to potentially deny your claim. Do what they ask, and hopefully they'll do the right thing. I'm looking forward to the (positive) outcome of this. Good luck!
Eric SS is offline   Reply With Quote
Old 02-26-2017, 11:35 PM   #22
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Originally Posted by Gen_Nick3.8 View Post
Hello everyone, Now that the 1LE is finnaly out and it has a massive amount of eqiuipment geared for the ultimate track experience; One feature has been left out that I haven't see anyone talking about Dry Sump Oiling system the Z51 has it so why did GM leave it out of the 1LE
My first thought - is it dry sump? - I think I read they could not fit it into the Camaro.
But this is why dry sump exists - very high probability
-or broke a valve spring.
They'll fix it up for you
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 02-27-2017, 01:04 AM   #23
cleoent
cleoent's Avatar
Did you check oil level before or after your first session?
Leo
2016 e-Force 2SS
Instagram @cleoent
Old 02-27-2017, 07:34 AM   #24
Hard Parker
Hard Parker's Avatar
Drives: ZL1
Oh wow
I was contemplating modding mine and tracking it after
2017 Camaro 1LE Nightfall Gray Metallic RIP ☠️☠️☠️
2017 Camaro ZL1 Black Exposed CF|Sunroof|6 Speed
Click HERE to follow my build!!
Click HERE to follow me on Instagram
#savethemanuals
Hard Parker is offline   Reply With Quote
Old 02-27-2017, 08:34 AM   #25
Vintage
Drives: 2017 SS 1LE
As to oil level - yes all good and always checked before each session. Same with tire wear and tire pressure as well as lug nuts. I felt the motor coming apart as I depressed the pedal and, before I hit 5k, it was all over. It happened in less than a few seconds.
Old 02-27-2017, 08:46 AM   #26
Tomiboy
Drives: 2017 Hyper Blue 1LE
08-09 C6 LS3 Z-51 had a 6 qt. oil capacity and a shallow oil pan due to the cars low stance. The dry sump was added in 2010 (GS) because of oil starvation issues on track during high g-force left handers. I believe we have a deeper oil pan and a 10 qt capacity that SHOULD keep the oil pickup submerged. I don't think GM would make that mistake again. At least I hope not.
Tomiboy is offline   Reply With Quote
Old 02-27-2017, 09:18 AM   #27
DFW1LE
DFW1LE's Avatar
I hope they repair and get the car back to you quickly. If any track is going to stress a car, that is certainly a track that would do it. Sounds like maybe a valve spring or retainer failure, but am interested to hear what the actual diagnosis is.
Old 02-27-2017, 10:05 AM   #28
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Just wait until the Mustang guys get wind of the 1LEs grenading on the track..... Lol
