Old 03-05-2017, 06:46 PM   #15
TJay74
Ah, good to know. Just have known for years that it was almost impossible to get iTunes music on a USB drive.
Old 03-05-2017, 06:49 PM   #16
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
You might still have problems with copy protected files. Haven't messed with their crap in awhile to know how to handle purchased music.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 03-06-2017, 04:24 PM   #17
danomar
Drives: 2017 2LT V6
I bought one of the really short 32g Scandisk drives, formatted it and put all of my songs on the drive. Plugged it in and no go.
I recently read that the older version of the SanDisk Fit will not play well with car audio systems. The newer version is supposed to be better, but there is a known issue with the older ones.
I got PNYs and they work acceptably well but often take several seconds to appear in My Media Library, and sometimes it takes a few minutes for albums to load. It might be because they are USB 2.0, but I used a USB 3.0 drive before which also was slow. I just bought a set of Samsung Fit drives which are USB 3.0 and are rated well for car audio. Maybe they will work better.
danomar is offline   Reply With Quote
Old 12-14-2020, 03:04 PM   #18
Andrew S
Andrew S's Avatar
Drives: Camaro 2SS Redline Edition
I think that this is just a problem with that model of pen drive, because I have the same issue. Other pen drives work, just nit the 32g Scandisk short stick :(
Andrew S is offline   Reply With Quote
Old 12-31-2020, 03:39 AM   #19
Plasar
Drives: 2017 ZL1 Vert M6
Arrow NTFS on 128 micro SD
Plasar is offline   Reply With Quote
Old 01-01-2021, 09:59 AM   #20
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
mylink's audio player i believe (at least the 2016) is based on some open source software that will play pretty much anything you'd expect non-proprietary players (without copy protection) to play. What they dont support is a wide range of metadata reading support.
So the system only white-lists based on filename extension the formats that it supports metadata for. But because it uses stupid filename matching and not mime/magic file format reading to determine the file data (like most good software would), you have the option of just renaming the files to circumvent the whitelist.
This means you can rename files to end in .mp3 even if it's not and it will play fine. I do this with all of my flac files. You dont get the meta data support, but i'll play flac files without metadata any day over mp3s if i'm playing over flash drive vs just streaming .
so tldr; if you test your file and it doesn't play, just rename it to .mp3 and test again and you may be surprised.
Old 01-01-2021, 05:33 PM   #21
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
I have been using the Sandisk Ultra Fit 32GB for about a year now, on a small hub. They work fine and music plays fine. I just bought two new one to rotate in with different music but haven't tried them yet.
I have mostly .mp3 files and the drives are FAT32
The new one are USB 3.1 Gen 1
Not sure what the first ones were. It all fit in the center console.
overdriv is offline   Reply With Quote
Old 01-01-2021, 10:32 PM   #22
Thanks a lot for the info, cellsafemode.
I'll consider this a feature and not a bug (btw it's many times faster this way because files don't need to be opened; plus, part of the metadata is stored at the end with some file formats, which means the player would even need to seek into those files).
Old 01-27-2021, 01:41 PM   #23
FarmerFran
FarmerFran's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
multiple sizes, format to fat32 and put my entire library on it. plays fine.
