Old 05-31-2017, 01:55 PM   #15
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Here's a video I found of a Thinkware F770 install in a 2017 Camaro SS, using the trunk fusebox and an auxiliary battery. Not a Blackvue, but the installation concept is still the same. Doesn't totally work for me. Convertible means no roof liner routing. Also means getting very creative about where to place rear camera.
Old 05-31-2017, 02:42 PM   #16
CME73
CME73's Avatar
Drives: 2017 Camaro 2SS
Originally Posted by Gator Brah View Post
remember which fuse you used? Im gonna be searching for a switched 12v source later. Definitely none in the trunk box lol
There is definitely both switched and constant 12v in the trunk, I used those to power my Blackvue power magic there. At least the 2SS. I can get the fuse numbers when I get back to my car this afternoon.
CME73 is offline   Reply With Quote
Old 05-31-2017, 02:44 PM   #17
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Not sure I'm following this. Are you saying route the cable from the underhood fuse box through the A-Pillar trim and up to the dash cam?
No, i said for non converts in the passenger A-Pillar you have a connector with both keyed power and power always on and ground do you need more then that?
2SSRS@Gen5diy is offline   Reply With Quote
Old 05-31-2017, 03:23 PM   #18
Gator Brah
Gator Brah's Avatar
Drives: 2016 Camaro SS
i didnt try them all but even the ones that would logically be keyed 12v power are hot all the time in the trunk box. No one here on the forum that i've found has been able to get switched power from the trunk. Plenty of folks have stuff wired to the trunk fuses but those devices are not switching off with the car and are gonna kill their batteries. That being said i'd love to be wrong here... that trunk fuse box is the perfect location for power
that sounds much easier than pulling wires through the firewall. You recall which wire was keyed by chance?
Gator Brah is offline   Reply With Quote
Old 05-31-2017, 03:28 PM   #19
Martinjlm
Martinjlm's Avatar
Well, since I have a convertible, I guess it won't really help. Thanks for the clarification.
Old 05-31-2017, 03:38 PM   #20
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Wireless charger fuse. Not sure the number, but it is definitely not hot unless the switch is on. I just used it this weekend for some footwell lights.
Old 05-31-2017, 03:48 PM   #21
Gator Brah
Gator Brah's Avatar
Unfortunately thats only good for the 2ss. No wireless charger on the ss and the fuse slot is dead. thanks though
Old 05-31-2017, 04:14 PM   #22
SuperSound
SuperSound's Avatar
What bugs me is I see some guys have fuses (that work) that would only be in a 2SS but they have a 1SS. It seems to be random though. There's a relay (K6) in my front fuse box which serves no purpose, but not all SS cars have a relay there, even in the same year/options. Almost like they switched suppliers or just didn't bother to check what was being installed on the line.
Old 05-31-2017, 04:15 PM   #23
2SSRS@Gen5diy
Pin #4 VT/GY is keyed and #13 BK is ground.
Old 05-31-2017, 04:30 PM   #24
Gator Brah
Gator Brah's Avatar
wow that is strange. I wish that were the case with mine lol.
awesome. Thanks a bunch for the info.
Old 05-31-2017, 04:40 PM   #25
2SSRS@Gen5diy
I have not seen a convertible? if they have the over head console, think it will have the same connector.
Old 05-31-2017, 04:42 PM   #26
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Also, something to keep in mind, you dont need to run ground to a wire (running the length of the car)... just wire it to any chassis component you can attach your camera's ground wire to. So you should only have to deal with finding the right spot for a power wire, ground is nearly everywhere.
If you can't find a nice fuse, you can always wire to the fender lights. I think those turn on with the car and stay on regardless of day/night and they're fairly easy to access.
Old 05-31-2017, 04:52 PM   #27
2SSRS@Gen5diy
If i may, remember to see how much amps are needed you dont want to pull to much or less then you need for power.
Old 05-31-2017, 07:00 PM   #28
GroundhogSS
GroundhogSS's Avatar
Did you have any luck with finding a place for the rear camera? I'm still looking at cameras and would like one for the rear.
Richard
Delivered: 08/15/2016
#TeamBeckyD
