#15 | |
Tampa Bay Camaros
Drives: '16 Hyper Blue 1LT Join Date: Jul 2016
Rubber baseboard from Lowe's or Home Depot. The one I got was like $2 and was large enough for two covers. I measured and cut so it tucks in between the glass and dashboard and blows air back towards the cabin. Sent from my iPhone using Tapatalk
2016 Camaro 1LT | V6 | A8 | Hyper Blue
#16 |
Car Enthusiast
Drives: 2017 Camaro SS FIFTY Join Date: Jul 2016
I did my mold with a large computer mouse pad.
2017 SS Camaro FIFTY
6MT, Nav, NPP, Black Bowties, Mishimoto OCC, Skip Shift Eliminator, GM Footwell Lighting, NGM Splash Guards, GM Blackout Tail Lights (SOLD) |
#17 | |
![]() Drives: 2016 2SS Join Date: Mar 2016
#18 |
Tampa Bay Camaros
Wow, that looks great Sent from my iPhone using Tapatalk
#19 |
![]() Drives: 1LT Join Date: Jun 2017
Could you post pics I have problem with mine fogging in FT Lauderdale FL
#20 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
#21 |
![]() Drives: 2017 Hyper Blue 2SS Join Date: Jan 2017
Hillbilly fix
Sure go ahead and get the dealer "fix", they only have to remove your windshield and dig into the vent. The dealer probably doesn't do windshield work to often so good luck with the headliner fitting and all of your electronics working after the "repair". I'll happily be running my fingers through my cool looking mullet and singing hee hee hee haw haw as I look out my fog-less windshield.
#22 |
![]() ![]() Drives: 16 Camaro SS Join Date: Jul 2012
What has the windshield R&R to do with the headliner and the electronics? Neither will be touched by removing the glass.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
#23 |
![]() Drives: 2013 ZL1 Join Date: Nov 2015
Wouldn't a couple empty beer cans layed on their side solve 90% of this problem?
#24 |
![]() ![]() Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
Defost block
I traced the outline of the defroster vent and overlaid it on a piece of 1/8" thick rubber. The rubber I used was the rubber step covering from Girots Garage and cost $22. I used that because it matches the dash. I then cut it out about 1 1/2" to block about half of the vent and used 3m molding tape across the back (closest facing the driver) so that the rubber can lift toward the windshield when I do want to defrost the front windshield and keep it in place. Works great and looks good. I would never let them tear into the dash to fix the issue. Too much to go wrong.
#25 |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Rainx anti fog spray works wonders. I've had this issue A LOT in my truck, used rainx anti fog spray and fixed it. My camaro never had this issue so I never had to use the spray. Give it a try.
Engine heat from outside to the windshield + cold air from vents = fog on windshield. The spray should fix that but if it doesn't, I think what craigss50 did is amazing. |
#26 | |
Madman
wow
A bandaid at that...sad..:(..mine (17 1ss) does same on windshield |
#27 |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
Just set your temp to 71 or above and you get little or none at all. No need for mouse pad covers and yanking your dash out.
#28 | |
![]() Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
Mine does it at 75-76 on full auto or with vents set to any setting or combination of settings (just face or floor and face for example). It doesn't matter. Seriously, if you guys don't have the issue, you're lucky and not understanding what those of us with it have going on. No offense, just gets tiring hearing people say take it off defrost or turn up the temp. |
| Tags |
| air conditioning, condensation |
