#15 |
![]() Drives: 16 Summit white, Ceramic white 2SS Join Date: Jan 2016
#16 |
Well time for an update. After a week of trying to get a hold of someone at MSD I have decided to try again on my own to fix it. Emailed them twice and called several times no response. -.- I can see that the top shell is warped on the right side like a potato chip and will not come down all the way to seal properly. (kinda seals when I put a C clamp on it, but still leaks) I have resorted to using black rtv silicone on the outside edges of the leaking corner. I made sure no rtv got on the inside of the intake seal just the outside. Fingers crossed when this sets up it will work. Going to test it again with water tomorrow night and hopefully install Sunday if all works out this time. For $1200 I got a missing bolt, a plastic covered hole, excessive plastic slag, air bubbles in the cast, a warped top shell, and zero response from MSD..... Never again. Buyer beware!
... I hate being the barer of bad news. |
#17 |
![]() ![]() Drives: 16 Camaro SS Join Date: Jul 2012
What shame. $1200 for a piece of plastic and they don't even do Vacuum or pressure test before shipping! No response from them either. they should give you a new intake and $500 back for this shit. Sorry for your troubles, but this is just absurd.
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: X-15 Velocipede Join Date: Mar 2008
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#20 |
![]() Drives: '16 Red Hot 2SS M6 NPP Join Date: Apr 2016
How old is the intake? Cant you just return it?
![]() '16 2SS, M6, Borla Atak |
#21 |
#22 |
Drives: 2016 Camaro SS Join Date: Oct 2016
I sent a direct email to someone at MSD with a link to this thread. Hopefully it will help.
Tim |
#23 |
I guess I'm asking what vendor you purchased it from to return to them unless you got it direct.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
No way would I have tried to fix that myself. Gives them reason to say the warranty is void because you modified it.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
#25 |
#26 |
Yotaman It was fine from the factory. I took the two halves apart and ported the runners. Some how the top shell either warped while I had it in storage or was warped to begin with and now after letting it release it wont go back all the way to plum. :(
#27 |
Gotcha. Didn't realize that. Good luck.
#28 | |
Novice Driver
