Old 01-27-2017, 08:51 PM   #15
steelheadrob
Tactical Garage
steelheadrob's Avatar
Ted,
My original question wasn't very clear.
I was wonder on your other tread
JANNETTY RACING LT1 SUPER STREET BRAWLER MAKES 700 RWHP 642 RWTQ ON 93 OCT 11.2 PSI
If you switch out the stock air box for a roto-fab, whether you could expect similar gains to bump the total to 710 - 712 RWHP. Or if the fuel limitation wouldn't allow an additional gains by switching out the factory air box.
Thanks
steelheadrob is offline   Reply With Quote
Old 01-28-2017, 07:47 AM   #16
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by steelheadrob View Post
Ted,
Thanks
Yes I would expect the same 12 and 12 from the Rotofab and red filter and a bit more with the dry filter.
ON pump gas we are up against an octane wall rather than a fuel delivery wall with this package.
So for instance If I tuned for the stock air box at that power level and added the Rotofab which in fact adds more air I expect I will have to pull more timing due to the octane wall, and it may end up being a wash.
The safer approach on pump gas is go back to the 85 mm pulley, add the Rotofab for the gains up top for a more efficient 700 RWHP.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-28-2017, 09:23 AM   #17
steelheadrob
Tactical Garage
Thanks Ted! I appreciate the education on how all the variables work together.
Old 01-28-2017, 09:44 AM   #18
parish8
Drives: 17 SS a8
would you mind sharing exactly what is done to the fuel system to get to the 725rwhp on e85?
lt4 pump and injectors i see. stock cam lobe and no lash cap? any meth? what about the intank pump?
got a guess on how much lower that number would be with an a8?
thanks!
Old 01-29-2017, 12:35 AM   #19
JaxChris
I think in one of the threads they mentioned doing the mechanical and LPFP with the LT4 injectors. The vehicle is a manual, so I don't think the lash cap would be needed. Ted did say no meth was used.
I would venture a guess of 2-3% (15-20whp) in additional drive loss with the 8L90, but your drag times would still beat the manual. You're still looking at 700whp with E85 and probably able to run a 10.2 in the 1/4 with the right wheels & tires in the back. With the manual, I think 10.4-10.5 and the new LT-1 modified champ on the current fast list. This last paragraph is optimistic guessing.
Old 01-30-2017, 07:38 AM   #20
JANNETTYRACING
thanks!
LT4 High pressure pump w lashcap, LT4 injectors, ZL-1 in tank pump.
Our cams are all ground with 32% lobe to accept lash cap.
I would expect about 3-4% less RWHP with an A-8
Ted.
Old 01-30-2017, 07:35 PM   #21
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I got the car back Friday and changed my flight for a business trip so I could drive it over the weekend. It's a legitimate beast and takes some getting used to lol. Once I felt it out a little I started testing some third and fourth gear pulls. Thank God I got better tires because even the Pilot Super Sports, all warmed up, would break loose a bit if you floored it in 4th already doing 70. I would be shocked if I came across anything that could keep up with me. It needs a few minor tweaks but we're going to sort those out when I get back. It's really an impressive package. Hats off to Ted and his team for the work they did. It's very well mannered if you drive it like a normal person, but drop the hammer and the speedometer can't even keep up with you. It accelerates so hard, instantly...I can't wait to get home just to drive it again
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 01-30-2017, 07:47 PM   #22
Stefano
Stefano's Avatar
Drives: 6th Gen NicKey Camaro & others.
"Our cams are all ground with 32% lobe to accept lash cap."
Nice gains! So you are using a lash cap on the pump along with the larger 32% lobes?
Stefano is offline   Reply With Quote
Old 01-30-2017, 08:06 PM   #23
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
What kind of power would you expect with say 110 octane?
Boost, Boost & More Boost
Instagram = BoostedSS
SC88 is offline   Reply With Quote
Old 01-31-2017, 07:12 AM   #24
JANNETTYRACING
Understand the lobe is not 32% larger at the nose,,, it is 32% shorter at the base which creates a gap that needs to be filled with a lash cap.
The lash cap by itself does not change fuel delivery.
Old 01-31-2017, 07:17 AM   #25
JANNETTYRACING
I would expect I could easily make 750+ RWHP without much effort, but I think we will play it safe for now this is still in fact a stock engine minus the cam package, making double stock power.
The last thing we want is a broken engine, although you must accept that possibility because that is a reality in the performance game.
Ted.
Old 01-31-2017, 10:29 PM   #26
SC88
Twin Turbo
SC88's Avatar
Drives: 2016 2SS
Ted.
makes sense.
Which one would make more power Meth + 93 or 110 octane?
I've never really given meth a thought but I continue to see high Hp setups using meth injection rather then higher octane. I know its Probably due to cost but at least theres not another potential failure that could happen.
Old 02-01-2017, 09:09 AM   #27
JANNETTYRACING
makes sense.
Keep in mind you need less liquid by volume with race gas vs E-85.
We also found that these engines do not like a lot of octane or Lead so I would recommend 100 Unleaded for max power on Gasoline.
It is my experience you will still make more power on E-85 than gasoline IF it weren't for the limiter being the fuel system parts availability at this time.
There are higher flowing high pressure pumps and injectors coming to market but you will fall off your chair when you see the prices.
We are making as much power as we are comfortable with on an stock long block using the LT-4 fuel system parts.
Anything above this power level will require forged internals and larger fuel system.
These engines are failing with Meth injection set ups across the nation but no one is talking about it.
Ted.
Old 02-01-2017, 09:17 AM   #28
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
simply impressive.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
