Old 01-17-2017, 10:25 AM   #15
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
My 6 year old step daughter lent me a helping hand when I was trying to get the header bolts started on the driver side. She came out into the garage at the right time.
EFI Tuning is offline   Reply With Quote
Old 01-17-2017, 10:29 AM   #16
Burly
Burly's Avatar
Didn't you eliminate primary cats before header install, did you use the Kooks green cats with these new headers?
Burly is offline   Reply With Quote
Old 01-17-2017, 10:33 AM   #17
EFI Tuning
EFI Tuning's Avatar
Yes I had the CA pipes installed. For the Kooks I went with the standard HF cats. I didn't think the Green cats were worth the added expense given that the car is tuned anyways. I didn't install the rear O2s. If I ultimately need them to pass inspection in 2 years I'll pop them in.
The cats tame down sound a bit from where it was with the CA pipes. The nice thing about the Kooks pipes is that you can swap between off-road and cats very easily if you desire to do so. Simple swap.
Tim
Old 01-17-2017, 11:20 AM   #18
oldman
Drives: SS 6 speed of course
Originally Posted by Razzaa View Post
My son is only 3 but I guess I could start him young!!
got a picture of my youngest when he was about 3 years old, with his electric truck on bricks and he under it "fixing" it. Note in Texas you can be '"fixing" to do anything but actually fixing som'ten.
Old 01-17-2017, 12:10 PM   #19
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
I started wrenching on cars with my dad when I was 10 years old. To this day I still do all of my own work within reason.
Old 01-17-2017, 07:48 PM   #20
EFI Tuning
EFI Tuning's Avatar
I won't say this will apply to every installation but on my car I encountered an arcing plug wire tonight. Cylinder #3. The wire is too close (looks to be barely touching) and started failing from the heat. I have the Holley 45 degree wires on order. I was able to rotate the boots to gain some clearance but it's still not ideal.
Just FYI
Old 01-17-2017, 11:00 PM   #21
Richie Carbone
Richie Carbone's Avatar
Drives: My work van for now
Just FYI
Sounds like 1999 all over again!
Richie Carbone is offline   Reply With Quote
Old 01-17-2017, 11:25 PM   #22
ULTRAZLS1
ULTRAZLS1's Avatar
Just FYI
1 7/8 should have a bit more clearance yes?
Old 01-18-2017, 05:04 AM   #23
EFI Tuning
EFI Tuning's Avatar
Yes there will be a bit more clearance due to the smaller diameter. Had I taken more time to rotate the boots upfront on this one cylinder I probably wouldn't have had an issue at all with the stock wires.
In the interest of finding the best approach I've ordered both the Holley 45 degree wires and the MSDs which have a bendable boot. I'll see which gives the best fitment and clearance. They will both be in tomorrow.
Red wires = more HP
Tim
Old 01-18-2017, 05:07 AM   #24
EFI Tuning
EFI Tuning's Avatar
I was quicker then and history will repeat itself again meatball!
Old 01-18-2017, 07:21 AM   #25
laynlo15
Drives: 2022 Lt1 A10
Long tubes?
Old 01-18-2017, 08:06 AM   #26
EFI Tuning
EFI Tuning's Avatar
Long tubes?
Yes
Old 01-19-2017, 09:49 PM   #27
EFI Tuning
EFI Tuning's Avatar
I went with the MSD wires over the Holley 45 degree. The bendable boots on the MSDs let you get perfect clearance. I wasn't impressed with the Holley's.
Tim
Old 01-20-2017, 12:51 AM   #28
vince3
Drives: 2022 Vivid Orange LT1-M6
Just FYI
Did the car run any different from the arching?
vince3 is offline   Reply With Quote
