Old 01-09-2017, 12:39 AM   #15
ULTRAZLS1
ULTRAZLS1's Avatar
Runs strong. Dyno who cares
Get some track #s good luck man and congrats on the sc. Not my plan or what I prefer but best wishes
Old 01-09-2017, 04:48 AM   #16
laynlo15
Drives: 2022 Lt1 A10
Yes its still really fast and held off another 50 hp Camaro till the curve. It would still be a really low 11 second car and might even bump into the 10s as it sits. We should have run it with the hood down, it was 78 degress in the shop and with the hood open with the rotofab it could have affected the runs somewhat, don't know how much. The other ss was running a stock air box with k&n filter so its closed to the inside elements.
Old 01-09-2017, 04:14 PM   #17
ADM PERFORMANCE
Drives: Anything I want
Hood open Hood closed we have seen 10-15hp difference with some intakes.
The numbers are fantastic for such a simple kit.
We may yank the Intercooler bricks from an LT4 and run it just like Magnuson is doing,2-3 degrees timing is generally 45-50 rwhp either way so money wise its not such a bad loss.
Good Job
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 01-09-2017, 05:26 PM   #18
RageWorx
RageWorx's Avatar
Drives: 2016 1SS A8 Camaro with MRC and NPP
I think those numbers are strong and this is a really great setup/concept (Kudos to Magnuson) with a ton of value and upgradeability. Also being able to chose different cooling paths (chemical vs mechanical charge cooling or both) should you desire is nice. Ugh I can't wait for spring already lol.
You will run awesome with this setup Congrats !
-Jon
2016 HB Camaro 1SS A8 with MRC and NPP 398rwhp/389tq stock #s(11.84 @ 117 DR only, ECS boost 550rwhp/510tq (dynapack #s) , same boost + AEM water/meth + ARH Headers/mids 600 rwhp+ (dynojet #s) TTP)10.8 @ 129.
2020 Ford Explorer
2003 SVT Cobra Coupe (just your average KB Terminator Cobra).
2013 Focus ST (e30 Tuned).
2004 Dodge 3500 Cummins Dually 6 spd manual (tow rig).
1997 Jeep Cherokee (Lifted and Locked XJ off-road rig).
RageWorx is offline   Reply With Quote
Old 01-09-2017, 05:37 PM   #19
wnta1ss
Drives: 2017 Camaro 1SS
Wow, the intercooler was worth quite a bit even at this low boost level. Your car gained 22% more hp from the Magnuson supercharger without an intercooler, and the other car with an intercooled Magnuson supercharger gained 33% more hp. Thanks for sharing the test results.
Old 01-09-2017, 06:58 PM   #20
solobaric
solobaric's Avatar
Drives: 2002 Camaro SS
I missed the background on your install. How/where did you get a non intercooled setup? Can't find one listed on any vendors site.
2017 1SS Hyper Blue M6
2001 Ford Lightning
solobaric is offline   Reply With Quote
Old 01-09-2017, 07:17 PM   #21
Snowblind
Snowblind's Avatar
Thank you for being open and honest about your results. The numbers may be slightly lower than anticipated, but your timeslip this spring will be your dyno....the true measure of performance.
What level of boost can you run on e85 and not run out of pump or injector window ?? If the answer is like 4, would you pulley up and run the corn ?? Less boost = less heat and the benefit of ethanol....just trying to think outside the box
Old 01-09-2017, 08:05 PM   #22
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
http://www.magnusonsuperchargers.com...-23-379-bl.htm
Old 01-09-2017, 08:32 PM   #23
laynlo15
There is no doubt its a good deal. Cam, headers, heads, etc is still about the same price and reliability of the supercharger is much better. Nothing inside the engine has been altered. Yes the intercooler is awesome, but if you want to get started on your mods this is it. If you just running on the street its great, it will take a bit more cool down at the track. However my car is pretty great at the track and its decent on the dyno. For my mods 11.71@118.66 with Cai and drag pack is pretty stout. It might just be a pretty bad ass with just the Maggie. I really don't know, but running up against a 16ss that just made 50 more hp on the dyno and he can't get by you at 126 mph might be pretty stout. Could be in the 10's, who knows, another 1/8 mile and he might have passed me. We won't know cause that was the only time we have run.
Old 01-09-2017, 08:41 PM   #24
Razzaa
Razzaa's Avatar
Very interesting indeed. Install for whole kit including Intercooler is 10-12hrs. I wonder how long they estimate this install time takes.
Razzaa is offline   Reply With Quote
Old 01-09-2017, 08:48 PM   #25
laynlo15
I think Matt did the other Camaro in about 9 hours.Which is about 3 more hours then my non intercooler.
Old 01-09-2017, 09:11 PM   #26
steelheadrob
Tactical Garage
steelheadrob's Avatar
Nice that the guys that want to do a FI build can do it in stages similar to the NA builds. Enjoy the extra 90hp for awhile, when you get bored with the new power you can add the intercooler and pick up the extra 50hp.
steelheadrob is offline   Reply With Quote
Old 01-09-2017, 09:34 PM   #27
laynlo15
In the works already. I did make a mistake by leaving the hood open with the rotofab and the inside temp of the shop being in the upper 70's. The intercooled Camaro had the closed stock airbox with K&N filter. I do believe I messed up, but that's in the past. Next time I'll do it right. Rotofab has the seal for the hood and I didn't use it as I should have. I might have seen a little more hp with the closed hood. Don't know for sure, but.
Old 01-09-2017, 11:49 PM   #28
Razzaa
Razzaa's Avatar
Did you have to tune after install?
