#15 |
![]() Drives: 2016 Red Hot 2SS Join Date: May 2016
Why are you considering this? I think S-Type is loud with smoothness to it vs Atak which sounds harsh loud IMO.
#16 |
#17 |
![]() ![]() ![]() Drives: Camaro 2017 1LE Join Date: Feb 2016
LOUDER !!!
So I am confused i get three different answers with three different shops including borla ATAK XPIPE WITH AFM Street Legal Do I need a Mid pipe attachment? what should be the price for all ? |
#18 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Borla comes in two parts. Xpipe/midpipe and the rear sections. For a full catback you would need to purchase the Xpipe (60609 or 60610) and the rear section (11924 Stype or 11925 Atak) [assuming you have AFM and NPP] If you buy only the X pipe and want to keep the rear stock NPP you will need a custom way to connect the X pipe to the stock NPP rear. You also have to cut the factory exhaust. If you buy only the rear section you still have to cut the factory exhaust but you can slip on the rear Borla section and clamp it on as thats how it was designed. If you want to keep all 4 cats and do the whole catback you would need to buy the 60610 but still cut the factory pipes behind the rear cats. Since there are no inspections where I live I bought the 60609 x pipe which deletes the secondary cats. It is a direct bolt up to the factory flanges so you do NOT have to cut the factory exhaust and it removes the rear unmonitored cats. Then you can bolt up either the 11924 or 11925 to the Borla X pipe. If you don't have NPP then everything above still applies but you would buy the cheaper non NPP rear sections. If you don't have AFM, again everything above applies but you would buy the cheaper non AFM xpipe/midpipe section. Part #'s are different, but fitment is identical. |
#19 | |
I want Atak , xpipe and mid and keep cats Thanks for your help |
#20 |
Snackbar Tuning
